Lights Dimming Throughout House - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 08:32 AM   #16
I had this happen in my last house. Went on for years, went through light bulbs like nobody's business. No one could find anything wrong. I hired an electrian at a later date to install an outside light and he told me that my home was like a large box of flowing electricity. I believe it had to do with an outside ground or panel ground. Very very dangerous. Get an explanation, some electricians are to lazy or just don't know. Ask questions on the phone before they come out to make sure they know what they are doing. It took about 5 electricians before one found it.
Flowing
Mark Seidler is offline   Reply With Quote
Old 03-31-2013, 10:00 AM   #17
Rewards Points: 756
Originally Posted by joecaption View Post
Unless someone was using your power to your house it would have no effect on your lights at a differant location.
That is incorrect.
Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
Dave Sal (03-31-2013)
Old 03-31-2013, 10:54 AM   #18
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
NOT correct .... usually there are 3-8 houses that share the same transformer on the pole or on the ground ....SO it could effect you ...
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Old 03-31-2013, 12:27 PM   #19
Dave Sal's Avatar
Rewards Points: 728
This is interesting. I first noticed this phenomenon a week ago on Sunday. I checked again every day this past week and it seemed like it was gone. Today however, (Sunday again) I noticed that the lights are dimming again. If other homes close to mine have an effect on my power, it could conceivably be a neighbor doing something on Sunday that requires a lot of power. Is this correct?
Dave Sal is offline   Reply With Quote
Old 03-31-2013, 12:30 PM   #20
Rewards Points: 516
CORRECT .. that "COULD" be an answer ....
do you have a hot tub or anything?
Old 03-31-2013, 12:31 PM   #21
Rewards Points: 516
LOL any of your nieghbors do and welding .....
Old 03-31-2013, 01:18 PM   #22
Dave Sal's Avatar
Rewards Points: 728
Actually I do have a hot tub in the back yard. Had it for over five years now and never noticed this problem before.
Old 03-31-2013, 04:35 PM   #23
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Could simply be an undersized transformer, sometimes people add loads and the POCO is never notified about these changes, or the POCO themselves overload a transformer...
Old 04-02-2013, 10:53 AM   #24
Dave Sal's Avatar
Rewards Points: 728
Update:
Well, I had the power company come out and this guy seemed pretty sharp. He changed out the power connection to the house (those cartridge things at the end of the wires, whatever they are called) and when I told him that the lights continued to flicker, he went up on the pole in the alley and said he put us directly on their power to see if the problem resolved. It did not. He said that he did everything he could and their end is fine, so since it is affecting the lights on multiple circuits it is a bad main breaker that needs to be replaced. He said it is not dangerous but needs to be changed as soon as possible. I will get on that right away. I assume that the power needs to be shut down in order to change out the breaker so I'll need an electrician as this is not something that I should do on my own. Is this correct? Thanks again for the responses.
Old 09-07-2013, 09:35 PM   #25
Dave Sal's Avatar
Rewards Points: 728
Final update.
Just wanted to let everyone know what the outcome was. Apparently there was nothing wrong with the main breaker in the house. The problem was a dying freezer. The unit finally gave out and we ended up losing a couple hundred dollars worth of frozen food. I believe the compressor was cycling on and off and that was causing the lights to dim. Ended up throwing out the old freezer and getting a new one. Problem solved and no more dimming lights.
The Following 3 Users Say Thank You to Dave Sal For This Useful Post:
jbfan (09-08-2013), Kyle_in_rure (09-08-2013), Philly Master (09-08-2013)
Lights in house dimming!!! Headed to Texas Electrical 6 03-21-2011 10:52 AM
House dimming problem getting worse victorb Electrical 7 01-06-2011 09:30 PM
Lights Dimming and eventually Circuit Trips ericy51 Electrical 1 09-20-2010 07:21 PM
House lights dimming Tluther Electrical 7 04-20-2010 09:12 PM
lights dimming when using the vacuum farmerde Electrical 21 12-08-2008 08:09 AM
