Lights Dim In Windy Weather - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 12:17 AM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Sometimes it's "normal" during high winds, but if you are getting sparks definitely get it checked if you have not. See if you can get a video, that way if the hydro company comes and it's not doing it anymore, at least you can show it to them. I'm sure they'll jump on that to fix it as it's a pretty big safety hazard. Unplug all electronics as suggested, this could be damaging.
Old 01-02-2012, 07:21 AM   #17
Rewards Points: 1,536
Originally Posted by Julius793 View Post
If its arcing at the pole you'll just go home?
Unless the responding fire crew brought equipment for fighting electrical fires, there is very little they can do here.
The crew could pass judgment that the arcing poses no immediate threat to homes in the area and then call the power company and leave. They might also advise nearby residents to turn off their main breakers to see if the arcing stops.
AllanJ is online now   Reply With Quote
Old 01-02-2012, 04:40 PM   #18
Rewards Points: 101
A tech came from the power company to look at the problem he turned off the power to the house and called in an emergency work order to have the problem taken care of. They ended up replacing the whole power line running into the house.
michaelson is offline   Reply With Quote
Old 01-02-2012, 05:11 PM   #19
High winds and a simple arcing wire here in the City of Detroit, an entire city block burned to the Ground. Call and keep calling till it is made safe!
http://www.msnbc.msn.com/id/39065393/ns/us_news-life/t/wind-whipped-fires-add-detroits-economic-woes/
Hardway is offline   Reply With Quote
Trouble with GFCI Outlet + Switch for pool lights kentf Electrical 5 05-23-2011 11:37 AM
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 07:20 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 06:28 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 09:55 AM
