Lights Dim In Windy Weather - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 03:13 PM   #1
Rewards Points: 101
Lights Dim in Windy Weather
I've noticed that whenever it's at all windy the lights flicker. I was outside today and I noticed that the power lines connecting the house to the pole are sparking near the pole. Is this normal?
michaelson is offline   Reply With Quote
Old 01-01-2012, 03:15 PM   #2
Rewards Points: 13,300
Heck NO call the power company now!
I'd also unplug anything that uses electricty. If it drops a nutral it can blow everything pluged in.
Old 01-01-2012, 03:16 PM   #3
Julius793's Avatar
Not quite if it is continuously sparking call the FD also
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-01-2012, 03:32 PM   #4
Rewards Points: 1,192
Thats a normal way to lose all your electronics.
bobelectric is offline   Reply With Quote
Old 01-01-2012, 03:45 PM   #5
Rewards Points: 6,652
So, did you call 911?
Old 01-01-2012, 03:47 PM   #6
Julius793's Avatar
Nope came to run it by all of us first
Old 01-01-2012, 03:57 PM   #7
It is just like people that I see posting on another forum I read through, that ask legal questions, or medical issues. Where is this world going, when the Internet now takes place of real emergency professionals.
Old 01-01-2012, 04:23 PM   #8
Rewards Points: 1,448
It's a power company emergency, not a general emergency. If you call 911 the result could be just having the power shut off. If you call the power company they will put the power back on before they leave.
Old 01-01-2012, 04:29 PM   #9
Julius793's Avatar
No when you call the FD they will stay there till the poco comes to deal with it
Old 01-01-2012, 05:09 PM   #10
Rewards Points: 87
Originally Posted by michaelson View Post
... I noticed that the power lines connecting the house to the pole are sparking near the pole. Is this normal?
It may be "normal," but it's not right. As the others said: Call your POCO ASAP and get 'em out there to fix it, before something's damaged or destroyed.
Most vulnerable are sensitive electronics (TVs, computers not on a UPS, etc.) and anything with a high-draw electric induction motor, such as refrigerators, A/C units and submerged water well pumps w/o thermal protection. Shut 'em off until the problem is solved.
Jim
More Power! is offline   Reply With Quote
Old 01-01-2012, 05:39 PM   #11
iminaquagmire's Avatar
Rewards Points: 338
The fire department will not babysit a power line. If it is a danger to the public, yes we would. But not if it is not a risk to the public. If it was laying on the ground we would but it it was still attached to the pole or even in a tree, we wouldn't. Arcing on the house yes but otherwise it its a POCO problem.
iminaquagmire is offline   Reply With Quote
Old 01-01-2012, 06:39 PM   #12
Rewards Points: 101
I called the power company and they're sending someone to evaluate it tonight.
Old 01-02-2012, 12:24 AM   #13
Julius793's Avatar
If its arcing at the pole you'll just go home?
Old 01-02-2012, 12:57 AM   #14
Rewards Points: 862
you will usually get a faster response from POCO if you call the cops (or FD).
But since you already called POCO, I would just wait and see if they show up when they said they would. If not, then call police.
And I agree 100% with others in that you MUST DISCONNECT all electronics immediately, or risk expensive failures!!
During Hurricane Irene, I observed wires sparking (due to bad connection) in the wind, and the house across the street had lights flickering in one room. I called the police, and they put it on the list of thousands of such issues they had running during the storm. Eventually POCO did get to the problem, but if it had been my house that was affected, I would have unplugged everything, and even turned off the lights, as the flickering would have driven me mad!
FW
Ultrarunner2017 is offline   Reply With Quote
Old 01-02-2012, 01:11 AM   #15
Originally Posted by bertsmitc View Post
I've noticed that whenever it's at all windy the lights flicker....
Never happens here. It has been rock solid, with 32mph wind gusts all day long.
Trouble with GFCI Outlet + Switch for pool lights kentf Electrical 5 05-23-2011 12:37 PM
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 08:20 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 07:28 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
