Lights Dim When Microwave Runs. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 04:45 PM   #31
Originally Posted by brric View Post
That is not true. On overhead services the customer is usually responsible for everything past the service drop, including up to the meter and beyond.
You are correct EXCEPT if the problem lies within the pan. Most pans are locked by the utility to prevent theft of service. Most utilities will provide, with a permit number, a free pan to customers. The reason they do so is because if you or I go out and buy any ole pan, their meter may not fit and they are only worried about the revenue. AllanJ is spot on.
Shauni is offline   Reply With Quote
Old 03-24-2011, 04:48 PM   #32
Master Electrician
Rewards Points: 3,874
Sorry, we open meter sockets all the time when the need arises. They may be tagged but they are not locked. A utility is not going to make a repair in a meter socket when it is the customer's responsibility.
brric is online now   Reply With Quote
Old 03-24-2011, 05:10 PM   #33
Originally Posted by jhon View Post
So I get hoe and see evidence of the power company being here. (Flashing clocks, meter tag cut off and on ground. So I run the microwave and I still have the problem. So I call the Power Company, and all they can tell me is that the case has been closed........ So they are going to send someone else out,,,,, ??
Did they charge ya $85?
Old 03-24-2011, 05:17 PM   #34
I have no clue. When I called back an hour ago, I just assumed they were coming back out tonight... Now I am not so sure...
My power company is leaving me in the dark (G)
Going to call them now, as my wife wants to go out to dinner. I won't go because I don't want to miss them.
jhon is offline   Reply With Quote
Old 03-24-2011, 05:17 PM   #35
I guess it all depends on locations then. I know that if you drill out a barrel lock you will get crap for it. You can cut a seal but not a lock. The pan is off limits if it's locked. But hey, maybe not where u are. I'm in Jersey so who knows...Says it right on the meter, property of.....
Old 03-24-2011, 05:23 PM   #36
I=E/R
a7ecorsair's Avatar
If they send someone else out and they pull the meter that would be a good time to make sure everything in the panel is tight. In post 13 you had this:
I did push on the wires about 6 inches away where it is insulated just to see if any of them were visibly loose. They seemed fine. The terminal moved a little but not the wire alone.
I'm not sure what you mean...
a7ecorsair is offline   Reply With Quote
Old 03-24-2011, 05:30 PM   #37
I will do that...
What I meant is that I pushed on the three main wires coming into the box (Where they were coated and with an wood ruler) to see if the wires were not screwed down tight. They appeared to be tight.
Old 03-24-2011, 05:31 PM   #38
Master Electrician
You are correct. Around here the customer must provide the meter socket. I have never seen one locked.
Old 03-24-2011, 05:33 PM   #39
Just spoke to customer service again. She told me the first guy that came out "re crimped the hot leads going into the box" Someone else will be out, but they don't know if it will be tonight or tomorrow. I hope they send someone different.
Old 03-24-2011, 07:56 PM   #40
Bricc where are you from fantasyland? Ive never seen a meter not barrel locked by the utility company. The utility company usually always provides the meters. Some of the stuff you say makes me suspect your validity of being an electrician.
jerseystyle26 is offline   Reply With Quote
Old 03-24-2011, 08:08 PM   #41
I=E/R
a7ecorsair's Avatar
What is a barrel lock? I've owned and lived in several different houses in MN and all I've ever had was a seal.
Old 03-24-2011, 08:34 PM   #42
Its a little steel tab that clamps on the meter. Pair of chops and you can cut it off. Its just a tamper free device they use so people cant mess with the meters. If they notice one is missing when theyre doing their monthly rounds, you could get in trobule(hefty fine)
Old 03-24-2011, 08:47 PM   #43
Rewards Points: 506
I've seen both seals and hard locks. In Oklahoma.
I believe one reason for not "hard securing" a meter could be for fire departments who need to cut power to a burning house.
jlmran is offline   Reply With Quote
Old 03-24-2011, 08:52 PM   #44
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Not every place has locks on the meter!
I have never encountered a lock, just a tag.
Where I live, the HO provides the meter pan, and the POCO supllies the meter.
jbfan is online now   Reply With Quote
Old 03-25-2011, 12:16 PM   #45
Problem solved, but not without a struggle.... The neutral crimp connection at the roof had corroded.....
So I call the power company again this AM and they tell me that there is no record of my call last night but they will send someone out by noon. Then the dispatcher calls me and tells me I need an electrician they are not coming out again, she says it is probably in the pan. I ask why the guy that came out yesterday didnít say anything and she tells me she is not going to give me a lesson in electricity and we exchange more words and she says to call an electrician and she will send someone out the meet him. While I am on the phone with the electrician, she (The dispatcher) calls me back and tells me to cancel the electrician, they are sending someone out and can I meet him there.
So I meet the guy and he looks up at the leads coming into my house shakes his head. He then pops the meter. He puts this guage on it and it reads 120 each side. Then he flips a switch to run a fan motor that is part of the meter that puts a load on the system. One goes way up, and one goes way down.
Looks up again and tells me that the guy that came out yesterday replaced the crimp on one of the hot's where the pole wires come to the house. Shakes his head and said if he was only going to replace one, it should have been the neutral because that was obviously the problem. And wondered why the guy did not run the meter to make sure it was OK.
So he replaces all the crimps (Including the one the guy did yesterday) puts on the meter and now there is a one volt variance with a load, which he said is normal.
Looks like I was a victim of a lazy employee.
Looks like you guys hit it on the head. I just want to thank everyone for all the help I received on this forum. Without it I would not have had the knowledge to challenge the power company so they can get it right.
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 07:20 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 06:28 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
adding lights mharwell01 Electrical 1 01-03-2009 03:59 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
