Lights Dim And Then Go Bright - ONLY ON ONE CIRCUIT - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 08:45 PM   #16
Rewards Points: 180
Yes they used to allow those but not with a bedroom on bath circuit..would be good to know if wired after 99 also..
hidden 1 is online now   Reply With Quote
Old 07-18-2013, 10:48 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by kbsparky View Post
Got a laser printer (or copy machine) connected to that circuit?
Those can cause similar symptoms .....
I have a laser printer before and it will cycle from time to time to keep it warm espcally if you leave them on standby mode which I useally turn it off if I don't need it for a while that will useally elemated the flickering lights.
Merci.
Marc
Old 07-19-2013, 05:35 AM   #18
Yes I do have an all-in-one wireless printer connected to that circuit as well, however as I had stated, I unplugged EVERYTHING from that wall outlet to make sure it was not an issue with the load so the only thing running on that particular breaker was the bathroom lights.
Tonight is the night that I will be pulling receptacles out of the wall and checking all the connections in the back. Wish me luck!
Thanks to EVERYONE who has provided feedback!! I really appreciate it!
djbillbraun is offline   Reply With Quote
Old 07-19-2013, 05:37 AM   #19
The bedroom outlet is not on the GFI. It is on the same breaker. The GFI is connected to the two bathroom receptacles above the double vanity and the one outside receptacle only.
Old 07-19-2013, 10:34 AM   #20
Rewards Points: 180
Bathroom circuit should not ever have bedroom w it .nor same breaker .NEC dedicated circuit .
Old 07-22-2013, 05:22 AM   #21
I want to thank EVERYONE for their input. After pulling 3 receptacles, the culprit was indeed the outside one. All 3 of them had the push-in type connections, however the outside receptacle I could push the neutral in about 1/4 inch more. I put everything back and voilá (sp?), the lights NO LONGER DIM AND GO BRIGHT! My wife is also happy that we did not need to spend hundreds of $$$ and no longer worried about a fire.
The Following User Says Thank You to djbillbraun For This Useful Post:
jbfan (07-22-2013)
Old 07-22-2013, 06:15 PM   #22
dmxtothemax's Avatar
Rewards Points: 5,346
Good on ya !
now sit down, and have a celebratery beer, or two.
dmxtothemax is offline   Reply With Quote
Old 07-23-2013, 06:51 AM   #23
Originally Posted by dmxtothemax View Post
Good on ya !
Already did my friend . . . already did.
Cheers!
Old 07-23-2013, 10:15 AM   #24
joed's Avatar
Rewards Points: 12,852
And then go back and move all the wires to the screws instead of pushing then in further and you shouldn't have this problem again.
The Following User Says Thank You to joed For This Useful Post:
Jim Port (07-23-2013)
Old 07-23-2013, 10:29 AM   #25
Licensed electrician
Rewards Points: 1,608
If they don't maybe they will remember where the problem was when it happens again.
Tags
breaker , circuit , dim
