Old 07-06-2012, 02:45 AM   #1
lights dim then go back to normal
The lights in my bathroom and bedroom go dim then back to normal. its been going on now for three days. Its not happening in any other room of the house. What could be the problem?
mc4330 is offline   Reply With Quote
Old 07-06-2012, 07:28 AM   #2
Likely a loose wire connection somewhere in the circuit.
If you aren't comfortable with electricity I'd hire an electrician to check it out and repair.
To DIY, you'd have to check the wiring and connections from the breaker box to each fixture/outlet, switch, junction box(es) to find the loose/broken connection. Entering the breaker box is the most dangerous place to work.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
mc4330 (07-06-2012)
Old 07-06-2012, 09:28 AM   #3
Bill Kearney
What Bob said. But what kinds of lights are in the room? Is there a dimmer? Could be the switch or lights need replacing. Start with something simple, pull the bulbs and try them in another room/fixture. If new bulbs do the same thing then it's likely the switch or wiring.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
mc4330 (07-06-2012)
Old 07-06-2012, 10:00 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Agreed .. probably a neutral wire at a backstabed connection on a receptacle but you never know what may end up as the cause.
The Following User Says Thank You to Stubbie For This Useful Post:
mc4330 (07-06-2012)
Old 07-06-2012, 01:44 PM   #5
Master Electrician
could be a motor kicking on that wasn't running before as well. Maybe a new window ac installed? shouldn't be on a shared circuit with the bath but hey WAY stranger things have happened.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
mc4330 (07-06-2012)
Old 07-06-2012, 04:54 PM   #6
It was a dark and stormy
Yoyizit's Avatar
What these answers have in common is that the resistance in the line is too high for the load on it. Another possibility is that an appliance is failing and so drawing excessive current.
Between a good or bad appliance and good or bad connections there are three ways to cause your problem. Complicating this is that a bad wirenut may show 0.05 ohm but this much resistance is perfectly normal for 10' of Romex.
To weed out which of these three possibilities is causing your problem, we need to know how many feet of what gauge Romex made of copper or aluminum runs back to your panel.
The Following User Says Thank You to Yoyizit For This Useful Post:
mc4330 (07-06-2012)
Old 07-06-2012, 05:03 PM   #7
Just in those two rooms? With the record heat we have in the midwest/Great Lakes region, the electric company can't keep up with demand. We have had a lot of dimming lights the last few days.
brgmgb is offline   Reply With Quote
The Following User Says Thank You to brgmgb For This Useful Post:
mc4330 (07-06-2012)
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 11:30 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Two Lights, Two Switches Headache darveaux Electrical 13 01-21-2011 12:47 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
