Lights Dim, Appliances Won't Run - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 10:03 PM   #1
lights dim, appliances won't run
this morning all of the lights were burning dim, I went to turn on a heater and the intensity of other lights changed. I shut off all of the breakers, turned on one at a time. Problem moved to different areas as I turned different areas on. Seems that when lights are dim and I switch on a breaker from the opposite side everything gets brighter. I can't seem to isolate the problem. When I plug in a heater somewhere else, the lights burn bright again, but the heater won't run. help
bugsaroo is offline   Reply With Quote
Old 12-09-2010, 10:21 PM   #2
Mad Scientist
You've got a loose neutral somewhere. This is very serious, and you should turn off your main breaker until it is fixed, as you are getting higher than normal voltage in some areas, and lower voltage in others. It can cook your electronics and appliances.
Call the power company, and get them to come out and check their connections. Often the problem is at the service entrance.
McSteve is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
