Lights Dim - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 03:26 PM   #1
lights dim
When my well pump kicks on and my dryer sometime my lights dim. its not just on one circuit either. Does anyone know what could be causing? maybe a loose ground in the service panel? thanks
mike242424 is offline   Reply With Quote
Old 07-07-2009, 08:25 PM   #2
joed's Avatar
Rewards Points: 11,520
Not an uncommon thing when large loads startup.
Old 07-07-2009, 08:41 PM   #3
Could be a lot of things, including normal.
Occaisionally my lights dim when my neighbors A/C kicks on.
All you can do is open up stuff and check connections/bus/terminals.
220/221 is offline   Reply With Quote
Old 07-07-2009, 09:15 PM   #4
Contractor in PA
If the problem is major issue with you, then contact the utility supplier. They will check out their equipment (which may be old or undersized etc) without charge to you. If it is their equipment, they will replace or repair their items. If the problem is on your end / side they will tell you.
michaelpwalton1 is offline   Reply With Quote
Old 07-07-2009, 09:25 PM   #5
Rewards Points: 2,350
Doesn't sound like a problem at all. Now, if some lights go dim, while at the same time others get very bright when a load kicks on, that's a problem.
Old 07-07-2009, 10:01 PM   #6
More than 1v drop with the dryer on is probably trouble.
Old 07-08-2009, 09:46 AM   #7
thanks for all the infor guys i appreciate it. Its nothing serious but i was curious to see what people had to say about it thanks again
Old 07-11-2009, 11:20 AM   #8
Send a message via AIM to ckellyusa
Hey, I wanted to add to this since I'm experiencing the same problem, but on a much more serious scale.
The one common thread is turning on the dryer makes the power drop almost 40 volts in one room. Sometimes this causing the voltage to spike in my room up to about 160.
Other times, something like the microwave or A/C could cause the lights to dim, other power to fluctuate throughout the house.
Electrician help please!!!
ckellyusa is offline   Reply With Quote
Old 07-11-2009, 11:42 AM   #9
This is a more serious problem and is probably a loose service neutral. Call the power company first, because they won't charge you to come out and check the connections on their side.
Old 07-11-2009, 11:58 AM   #10
I did call the power company (TXU) and they said they would send someone out.
I never heard from them, but they told me I wouldn't unless there was a serious problem.
Old 07-11-2009, 12:38 PM   #11
It is a serious problem, as your sensitive electronics and appliances can be destroyed by this situation. Call them until something gets done. 9 times out of 10 this is a problem on their side. They need to come out and apply a load test at the meter. This is the only valid way they can check it. If they only do a visual inspection, they may miss it, as has just happened with another poster on a different thread.
Old 07-11-2009, 01:35 PM   #12
Not an electrician, but this means you have 40vac across a bad neutral connection.
Pulling 16A or so through this neutral connection means 40v x 16A = ~600w. If this is a bolted connection it must get extremely hot.
Your incand. lamps should have 2% of their normal lifetime at 160v.
Old 07-11-2009, 07:14 PM   #13
WFO
Unless the dryer is a 120 volt appliance (which I doubt) it is unusual for a 240 volt load to cause a rise in voltage. From the description of your problem, I agree with everyone else about a neutral problem.....I'm just wondering if you have some bad connections elsewhere to boot.
WFO is offline   Reply With Quote
Old 07-11-2009, 07:57 PM   #14
Dryers are usually 120/240 V. The motor and system timer is 120 V, and sometimes the low heat setting is 120 V, while the high heat setting is 240 V.
Old 07-11-2009, 11:29 PM   #15
WFO
Ooops. My bad!
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
