Lights Dim - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-14-2008, 01:40 PM   #31
Originally Posted by TazinCR View Post
If the neutral goes out doesn't he end up with nothing except 220 outlets with no neutral and no power on the 110v outlets. Where would the 220 to the outlets come from if the neutral breaks?
Use a pencil/paper and draw the circuit including a load and you will see.
If there is no 120 loads, there is no 240 path.
220/221 is offline   Reply With Quote
Old 12-14-2008, 02:39 PM   #32
I can't post spreadsheets but here is one that is self explanatory that analyzes a resi. circuit.
Ia, Ib are the currents circulated due to V1, V2, respectively
They both go through Rn, the current through Rn being Ia - Ib.
120.0 ent V1, volts
120.0 ent V2, volts
0.1 ent Rn, ohms
40.0 ent R1, ohms
20.0 ent R2, ohms
20.1 calc'd A= Rn+R2=
40.1 calc'd B=R1+Rn=
4,824.0 calc'd Num1= V1*Rn+B*V2
806.0 calc'd Denom1= (A*B)-(Rn^2)
6.0 calc'd Ib= Num1/Denom1, amps
120.6 calc'd Num2= C*Rn + V1
40.1 calc'd Denom2= B
3.0 calc'd Ia= Num2/Denom2, amps
1,079.1 calc'd total power in, (V1*Ia) + (V2*Ib), watts
0.9 calc'd power dissipated in Rn, [(Ia-Ib)^2]*Rn, watts
361.8 calc'd power dissipated in R1, [Ia^2]*R1, watts
716.4 calc'd power dissipated in R2, [Ib^2]*R2, watts
1,079.1 calc'd total power dissipated, watts
0.3 calc'd voltage across Rn, volts
120.3 calc'd voltage across R1, volts
119.7 calc'd voltage across R2, volts
0.6 calc'd voltage difference, R1-R2, volts
Old 12-14-2008, 04:49 PM   #33
Whatamess
Thanks 220 got it. I was not thinking about a load just the outlet.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 12-14-2008, 05:53 PM   #34
electrician
120.0 ent V1, volts
120.0 ent V2, volts
0.1 ent Rn, ohms
40.0 ent R1, ohms
20.0 ent R2, ohms
And I thought I was bored today
Silk is offline   Reply With Quote
Old 12-14-2008, 05:58 PM   #35
Is God perfect?
Therefore, does He (or She) speak a perfect language?
Is mathematics a perfect language?
'Nuff said. . .
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
