Lights Continually Flicker While Heating System Running - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 02:43 PM   #1
Lights continually flicker while heating system running
I recently purchased a home which had all the wiring, switches, outlets, panel, service, etc. replaced within the last 7 years (presumably by a qualified electrician, it was permitted and inspected). There's a 200 amp panel with 3 dedicated 240v circuits for the radiant floor heating (30 amp for pump, and 2- 50 amp for electric water heater). Lighting, outlets, other appliances, etc. are on separate circuits.
When we turned on the heat for the first time last night we noticed that all the compact flourescent and halogen lights in the house would flicker (faint strobe effect) wile the system was running. Everything I've found so far relates to lights flickering/dimming when a high current appliance turns on, not continual flickering while running. I haven't noticed this with any other appliances (clothes dryer, window A/C, or dishwasher).
With the exception of the service wires coming into the 200 amp panel, I have ensured that all the wire connections within the panel are tight. No discolored wires or insulation in there.
The symptom is not a dimming of the lights when the heating system comes on, it is continuous flickering when the system is running.
Is this symptom similar to a high current draw, or is it related to something else?
Any ideas for troubleshooting are appreciated.
bshep is offline   Reply With Quote
Old 02-16-2014, 09:11 PM   #2
Did you ever figure out the solution to your problem?
dynasty200dx is offline   Reply With Quote
New H2O heating and cooling system dscott76 HVAC 1 02-03-2011 02:54 AM
Changing my heating system, need advice sethfc HVAC 4 08-10-2009 09:46 AM
Wanna help design a hydronic radiant heating system? YerDugliness Green Home Improvement 4 05-03-2009 10:10 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 07:27 PM
