Lights Come On When I Plug In The Vacuum - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 07:58 AM   #1
Lights come on when i plug in the vacuum
The overhead lights come on when i plug in the vacuum, at my business. The lights only come on when the vacuum is plugged in. They do not come on when i turn on the switch.
dkusa is offline   Reply With Quote
Old 07-13-2012, 08:15 AM   #2
Rewards Points: 3,256
What kind of lights are they? Are you saying that you have lights that are totally useless because you normally can't get them to turn on with the switch?
zappa is offline   Reply With Quote
Old 07-13-2012, 08:24 AM   #3
Rewards Points: 6,652
I would have to guess that the vacum is completing the circuit. Since this is a commercial building, you will meed a licensed electrician to check it out.
The Following User Says Thank You to gregzoll For This Useful Post:
andrew79 (07-13-2012)
Old 07-13-2012, 08:24 AM   #4
Master Electrician
I think you've got a crossed neutral. When you plug in The vacumn your backfeeding the lights through the neutral. That's my best guess without more info.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-13-2012, 03:31 PM   #5
Or a bad neutral, if the vacuum draws much more current than the lights.
If just plugging in a turned off vacuum makes the lights come on, you need an exorcist.
Old 07-13-2012, 03:40 PM   #6
Licensed electrician
Rewards Points: 1,884
The loose connection might be in the receptacle that the vacuum get plugged into.
Tags
lights , vacuum
Lights still dimming and flickerin Keisha34 Electrical 18 06-08-2012 11:14 PM
Dimming and Flickering lights in home Keisha34 Electrical 34 06-05-2012 02:22 PM
Changing from florecent lights to canned lights, currently 2 sets of wires & I need 4 clueless@wires Electrical 2 04-16-2012 06:21 AM
lights dimming when using the vacuum farmerde Electrical 21 12-08-2008 08:09 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
