Lights On A Circuit - Role Of Bulb Wattage? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 09:49 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 690
Lights on a circuit - role of bulb wattage?
I have read some conflicting information on the following. Looking for someone to advise.
Facts: Installing 35 recessed fixtures on multiple circuits. The fixtures are made for up to 75w bulbs. I plan on using 15w compact fluorescent bulbs in the fixtures.
When calculating the number of fixtures per circuit, do I need to use the maximum allowable bulb wattage (75), or the intended bulb wattage (15)?
hyunelan2 is offline   Reply With Quote
Old 01-24-2012, 09:51 AM   #2
Just call me Andrew
Rewards Points: 1,020
The maximum.
At 120v, each lamp could use 75 watts, or 0.625 Amps.
Andrew
secutanudu is offline   Reply With Quote
Old 01-24-2012, 09:52 AM   #3
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
+1 to the Maximum.
Big N8 is offline   Reply With Quote
Old 01-24-2012, 09:52 AM   #4
Licensed electrician
Rewards Points: 1,496
Even tho you are installing the 15 watt bulbs, someone could later install the 75s.
Old 01-24-2012, 09:56 AM   #5
hyunelan2's Avatar
Rewards Points: 690
Thank you. I agree with all of you, and that is what I thought.
I had someone almost jumping up and down (on the internet) telling me that the circuits only needed to meet the intended use and not the maximum.
One more question. As to the loading of the circuit, is there a recommended cut-off (say 80%) for light fixtures? So, a 15a circuit at 120v would be 1800w, is it advisable to only load it to a maximum of 1440 (80%) or other arbitrary percentage?
Old 01-24-2012, 10:02 AM   #6
Residential circuits are not limited to the 80 percent. Rarely, if even would you have all the lighting on for 3 hours or more.
Old 01-24-2012, 10:30 AM   #7
According to cec, you can put a max of 12 devices on each circuit.
fdiddy is offline   Reply With Quote
Old 01-24-2012, 01:07 PM   #8
MarginallyQualified
Rewards Points: 2,464
If cord and plug connected and has a UL sticker... Maybe.
Hard wired? Nope.
...loading of the circuit, is there a recommended cut-off (say 80%)...
So, a 15a circuit at 120v would be 1800w, is it advisable to only (hard wire connect) load it to a maximum of 1440 (80%)
In short... yes. Not NEC; but "best practices" will limit loads.
Knowing about potential loading is why K&B's require 20A circuits
Light bulb sockets and wattage ratings Richo Electrical 5 12-19-2014 10:42 AM
Voltage drop? Lights dim with load on different circuit. nezwick Electrical 28 08-14-2012 10:18 AM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 04:20 PM
Multiple lights and switches on one circuit Straightgrain Electrical 5 03-31-2009 07:34 AM
