Lights On Circuit With Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 03:44 AM   #16
Rewards Points: 866
Originally Posted by Jim Port View Post
Sounds like a good plan. Especially if you can replace the #14 easily/
I am going to call for an electrical inspection this week on a permit pulled in December for some extensions to other circuits for ceiling fans and lights. At the time, if the inspector is as cool as I think he is, I will ask him about this circuit. There are two different issues that I see. The first if it was code when installed in around 1991 and the other is whether it is safe.
Should either code or safety require it be a 20 amp circuit, there may be a bit more work involved as so far it looks as all the receptacles and switches on this circuit is wired to #14, with the exception of the wire coming off of the main panel breaker.
[Since posting the above I found a site indicating that the installation was code when my home was built in 1990 or 1991. "The bathroom outlets in homes built after the mid-’90s are required to have dedicated 20-amp circuits for this very reason." http://www.rd.com/19764/article19764.html Of course, that site may be wrong, but even if it is correct, I will still plan on upgrading the circuit to a 20 so as to reduce the risk of an overload. Comments]
Last edited by Klawman; 02-22-2010 at 04:55 AM. Reason: Located info on mid-90's code change
Klawman is offline   Reply With Quote
Old 02-22-2010, 07:51 AM   #17
Originally Posted by Snav View Post
Interesting - I don't live in California so I'm not up with the code, there.
But I guess that might explain why several homes I've lived in haven't had overhead lights. . . always irritated me - and I always installed them.
Shame on me, I guess!
But, yeah, it's a standard that certain circuits must be isolated (your stove, hot water heater, dryer) . . . or strictly to the necessities of the room itself (bathroom can have air vent - air vent can have light, etc).
I also hate houses with no overhead center of the room lights.
SULTINI is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Outlets from multiple baths on the same circuit? BimmerRacer Electrical 10 01-27-2010 01:33 PM
lights and outlets iskibumi Electrical 2 08-18-2009 12:03 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
Adding lights to a circuit.. Pl check circuit aw44 Electrical 4 08-27-2008 03:09 PM
