Lights Blinks When Another Appliance Is Switched On - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 09:08 AM   #1
Cool
lights blinks when another appliance is switched on
I just moved into a new house, well, the house is over 50 yrs old and not really new.
it has 100A for the board.
one issue with the electrical is that whenever I switch on some heavy equipment like a pump or vacuum cleaner, other light in the room blinks, for just a second.
I went to the board and found that all circuit breakers are of 20A, not 15A. so this is not because of the insufficient power supplied from one of the c/b.
what can be the reason?
quanpenter is offline   Reply With Quote
Old 12-04-2012, 10:07 AM   #2
Rewards Points: 150
The additional current drawn by the pump, etc., causes a momentary drop in voltage. This voltage drop will often cause a flicker, especially in incandescent lights. In a fraction of a second, your power source adjusts to compensate to the additional current demand.
Unfortunately, a marginal wiring connection can also cause the flicker. You might want to check all the connections on that branch circuit to make sure they're clean and tight.
Dave632 is offline   Reply With Quote
Old 12-04-2012, 10:27 AM   #3
thank you Dave.
yes, my incandescent light flicks, but not for my tube light. I'm going to check any loose connection along the line.
so which line you think is loose, the supply to light or to pump?
thanks
Old 12-04-2012, 10:38 AM   #4
Rewards Points: 150
Probably to the light, but that's just a guess.
Tags
blinking lights , dimming light
Lights still dimming and flickerin Keisha34 Electrical 18 06-08-2012 11:14 PM
Lights blinks even after switching off the power Khali Electrical 3 02-18-2009 10:03 AM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
adding lights mharwell01 Electrical 1 01-03-2009 03:59 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 09:55 AM
