Lightning Vs CEE Off-the-wall Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2009, 03:15 PM   #1
Rewards Points: 1,910
Lightning vs CEE off-the-wall question.
After seeing the massive destruction that a lightning bolt can do the thought (question really) popped into my mind of what happens when lightning strikes the electrical system of a house using the rebar in the footing as the ground (concrete encase electrode).
Has anyone ever heard of a lighting strike cracking the footing of a house using a CEE (maybe no one knows cause it's hidden from view).
Similar question - should lightning rods on a house be grounded to the same CEE as the houses electrical system or separate ground rods?
Odd questions I guess but it's Friday.
Old 07-18-2009, 09:15 AM   #2
i would use ground rods .your trying to send the lightning to the ground not your panel its just safer with ground rods
javier is offline   Reply With Quote
Old 07-19-2009, 11:06 AM   #3
WFO
I have a master electrician friend who's seen a slab blown to pieces by lightning getting into the rebar. He is definitely not a fan of that particular code requirement.
WFO is offline   Reply With Quote
chinese dry wall question damyankee007 General DIY Discussions 15 12-15-2009 06:21 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
knee wall question jscholl411 Building & Construction 7 10-10-2007 12:30 PM
