Lightning Stirke, Breakers Tripped... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-22-2008, 09:49 AM   #16
Master Electrician
JohnJ0906's Avatar
Originally Posted by jrclen View Post
Make sure all ground rods on the premises are bonded together. Telephone, electric, antenna, well casing if you have one, and metal water pipe coming in from underground.
Lightning travels through the ground from where it strikes, in gradients. Dropping in voltage as it goes. So a ground rod for say the telephone on one side of the house could be thousands of volts different from the electric service ground rod on the other side of the house, if they are not bonded together. That voltage is going to try to equalize by flowing through your circuits and equipment.
This is worth a second read.
Bond, bond, bond. Keep that gradient low as possible.
Lightning can induce voltage, without any direct strike.
I went to a Mike Holt Grounding/bonding seminar last year, and the way he put it was, we try to minimize the damage from induced voltage the best we can . Direct strike - you are screwed.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Arc Fault breakers (warning) Potomac101 Electrical 68 01-05-2012 04:22 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 11:19 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
Zinsco breaker boxes and breakers. evosounds Electrical 3 07-29-2007 07:08 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
