-   -   Lighting tip needed for vaulted ceiling (http://www.diychatroom.com/f18/lighting-tip-needed-vaulted-ceiling-6677/)
wease 02-24-2007 08:07 AM
In terms of wiring, how can I install lighting in a vaulted ceiling where I can't run wires in the insulated area? In other words, it would need to be wired on the inside portion of the ceiling.
Not a big fan of those boxed runner strips. Any other thoughts? I'll be installing tongue and groove ceiling board and there will be timber trusses as well. Can I run it under some of that somehow?
jwhite 02-24-2007 08:41 AM
If you are using the toung and groove, why can't you tear up the dry wall and run the wires inside the wall cavity?
wease 02-24-2007 09:11 AM
I guess I should be more clear. This will be new construction. I am using a sip panel and I don't want to penetrate the structure. Therefore, I'd like to find a solution that can get the lighting up there without running it in the normal fashion.
There will be no drywall. SIP panel and t&g.
Stubbie 02-24-2007 09:44 AM
Any hollow beams running the peak? Maybe somekind of cosmetic decorative wood channel to run the romex in? Otherwise an old standby is wiremold but it aint very pretty.
Stubbie
wease 02-24-2007 11:32 AM
Nope, nothing hollow. That's the problem. I may need to find some out of the box idea for lighting.
Stubbie 02-24-2007 11:49 PM
If you can router some channels in the timbers you could lay the romex in those then trim over.
Roger
