Old 10-07-2012, 01:43 PM   #1
Lighting a small walkway (outdoors)
I need to light a small walkway outside. Electrical sources is available nearby. Should be around 9 ft tall from ground due to nearby bushes.
However, I do not have much experience or tools needed to mount something to a wall, so I was going for the tripod/post approach.
I was thinking of getting this: http://www.cowboystudio.com/product_p/w807%20stand.htm
and this: http://www.amazon.com/Lithonia-OFL-300-500Q-120/dp/B001YRAWWO
Can one be mounted to the other? How? Any other ideas?
vassock is offline   Reply With Quote
Old 10-07-2012, 02:01 PM   #2
Is this something that's only going to be a quick fix and temperary?
If not then that's not the way to go.
A picture of the area your working on would be a much bigger help.
Old 10-07-2012, 02:42 PM   #3
The Xs indicate the area that needs to be lit. I was thinking of placing the tripod at the corner of the part of the house visible in the drawing.
It would be a permanent installation.
Old 10-07-2012, 02:55 PM   #4
You would be far better off with a simple lamp post set where the sidewalk makes the turn with a senor on it.
Low voltage or solor lights set up along the walkway.
Or a set of spot lights installed up in the gable on the wall of the house.
I know you said you did not have the tools or know how to do something like these suggestions but the way your suggesting is just plan ugly. plus having to run an extention cord across the yard to run it, then have to come up with a way to switch it on and off just makes no since to me.
Old 10-07-2012, 03:19 PM   #5
http://www.amazon.com/Maxsa-Bright-S...y+lights+solar
http://www.amazon.com/Sunforce-82151...y+lights+solar
http://www.amazon.com/GIVESURPRISE-S...y+lights+solar
http://www.amazon.com/Ultra-Bright-M...y+lights+solar
okay just some other ideas from amazon, most of these can be easly mounted with just a drill
redman88 is offline   Reply With Quote
Old 10-07-2012, 03:21 PM   #6
biggles's Avatar
solar foot light along the foot path as you walk to the front door on the right side light the walkway or a 115V/24V light post just below the E in bushes will paint the front and the walk way with a 60w energy bulb...might try the path lights then add going all solar so no switching wires are involved....HD/LOWES has loads of solar lights..maybe a solar near the front door forget the tripod keep the lighting soft
Old 10-07-2012, 08:39 PM   #7
What if there is heavy wind/snow? A post seems less sturdy than a tripod. I don't mind stretching a cable to an electric power source. My main problem is reliable mounting so it doesn't fall down in unfavorable outdoor conditions.
Old 10-07-2012, 08:51 PM   #8
The post gets set in concrete, it's not going anywhere unless someone backs into it with a car.
Just look around your area. There millions of homes with lamp post.
Just a guess, is this your first house?
Old 10-07-2012, 09:09 PM   #9
creeper's Avatar
I've got a solar post buried in just soil.. Its not going anywhere. In your case I'd mount a solar motion detector on the corner of the house
Here is a picture of the buried lamp post
creeper is offline   Reply With Quote
Old 10-07-2012, 09:22 PM   #10
http://www.bing.com/images/search?q=...ures&FORM=IGRE
Wiring for under cabinet lighting fredm54 Electrical 15 06-16-2012 01:23 PM
Where to find bulk small wire? Red Squirrel Electrical 13 06-14-2012 10:38 PM
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 7 05-06-2012 11:43 PM
Lighting layout for lounge area timbo59 Electrical 3 11-21-2011 06:37 AM
Repair crumbled brick walkway timcsi Building & Construction 12 12-18-2009 12:11 PM
