Lighting In Shower - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 09:53 PM   #1
Lighting in shower
Is it necessary to use a GFCI with the recessed lighting in a shower area.
Dominick Reis is offline   Reply With Quote
Old 10-30-2011, 10:36 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Typically no, unless the manufacturer requires it in their instructions, but fyi, many/most fans installed in a shower area will require GFCI protection as per the instructions.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Speedy Petey (10-31-2011)
Shower Lighting FrazaFraze Interior Decorating 3 10-29-2011 07:13 PM
Shower Lighting and fan stopped working (separate fixtures on same circuit) IndyNotHandy Electrical 15 03-15-2011 09:39 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom remodel - lighting over shower / water line s4alex Electrical 15 10-10-2008 01:15 AM
Recessed Lighting above shower cooper4x4 Electrical 23 08-07-2008 04:51 PM
