Old 10-30-2010, 08:33 AM   #1
Master General ReEngineer
Bondo's Avatar
Lighting, 'n outlets on the same breaker ??
Hi, I'm remodeling/ rebuilding the lower floor of a house here in extreme northern Ny...
It's a single room with 3 light fixtures, 'n 3 outlets. Total load will be well under 20amps.
Is it to code to run a single breaker that controls Both the lighting, 'n the outlets...
Or,
Do I have to run seperate circuits, 1 for lighting, then another for the outlets ? ?
Thank you...
Old 10-30-2010, 08:41 AM   #2
Master Electrician
Unless there are local restrictions there is absolutely nothing wrong with wiring the room as you propose.
brric is offline   Reply With Quote
Old 10-30-2010, 08:47 AM   #3
Xtreme DIY'r
I usually add lights to an existing lighting circuit
I prefer to keep them separate
But as stated nothing wrong with putting them all together
Old 10-30-2010, 09:41 AM   #4
Licensed electrician
Given the low load and the cost of an additional AFCI breaker at $50 I would just use one circuit.
Old 10-31-2010, 09:16 AM   #5
Bondo's Avatar
Ayuh,.... Thanks guys,... You all confirmed my thoughts....
Old 10-31-2010, 12:24 PM   #6
If you plug something in that trips the breaker it might get a little dark.
jmc1981 is offline   Reply With Quote
Old 10-31-2010, 01:21 PM   #7
Electrical Contractor
If it rains, you might have a roof leak!
People are so worried aboiut tripping breakers.
The last time I tripped a breaker was......Never at home.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-31-2010, 01:42 PM   #8
Your right I think I've had a beaker trip once in my house.
I work in a industrial plant I'm just usto breakers tripping.
Old 11-01-2010, 04:47 AM   #9
Bondo's Avatar
Ayuh,... That's what Flashlights are for,...
Old 11-01-2010, 07:56 AM   #10
If there is a lot of lighting load to be put on the same circuit (rare in a home setting), a separate circuit for the lighting is recommended. You don't want a 15 ampere circuit to "deceptively" have only 7 or 8 amps for things you plug in. (Or a 20 amp circuit to have only 12 or 13 amps remaining)
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 11-01-2010, 09:20 AM   #11
Bondo's Avatar
Ayuh,... Thanks Allen,...
Anticipated load is 3 60w overhead lights, 'n maybe a tablelamp...
Outlet loads should only be a TV, 'n possible a small music center...
I think a single 20amp circuit should cover it all...
Also,... All wiring is 12ga. 3 conductor wire...
Old 11-01-2010, 09:21 AM   #12
Just make sure you have a flash light in your back pocket every time you plug in something.
Old 11-01-2010, 09:28 AM   #13
Xtreme DIY'r
I have flashlights in my house
Not hard to find them when needed
And my key chain has a small LED flashlight
And I've had far more short power outages from weather etc VS breakers tripping
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 09:20 PM
3 outlets and a light off a new breaker racebum Electrical 4 06-29-2010 09:42 AM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 05:13 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
