-   -   Lighting, 'n outlets on the same breaker ?? (http://www.diychatroom.com/f18/lighting-n-outlets-same-breaker-85278/)
Bondo 10-30-2010 08:33 AM
Hi, I'm remodeling/ rebuilding the lower floor of a house here in extreme northern Ny...
It's a single room with 3 light fixtures, 'n 3 outlets. Total load will be well under 20amps.
Is it to code to run a single breaker that controls Both the lighting, 'n the outlets...
Or,
Do I have to run seperate circuits, 1 for lighting, then another for the outlets ? ?
Thank you...
brric 10-30-2010 08:41 AM
Unless there are local restrictions there is absolutely nothing wrong with wiring the room as you propose.
Scuba_Dave 10-30-2010 08:47 AM
I usually add lights to an existing lighting circuit
I prefer to keep them separate
But as stated nothing wrong with putting them all together
Jim Port 10-30-2010 09:41 AM
Given the low load and the cost of an additional AFCI breaker at $50 I would just use one circuit.
Bondo 10-31-2010 09:16 AM
Ayuh,.... Thanks guys,... You all confirmed my thoughts....
jmc1981 10-31-2010 12:24 PM
If you plug something in that trips the breaker it might get a little dark.
jbfan 10-31-2010 01:21 PM
If it rains, you might have a roof leak!
People are so worried aboiut tripping breakers.
The last time I tripped a breaker was......Never at home.:whistling2:
jmc1981 10-31-2010 01:42 PM
Your right I think I've had a beaker trip once in my house.
I work in a industrial plant I'm just usto breakers tripping.
Bondo 11-01-2010 04:47 AM
Ayuh,... That's what Flashlights are for,...:)
AllanJ 11-01-2010 07:56 AM
If there is a lot of lighting load to be put on the same circuit (rare in a home setting), a separate circuit for the lighting is recommended. You don't want a 15 ampere circuit to "deceptively" have only 7 or 8 amps for things you plug in. (Or a 20 amp circuit to have only 12 or 13 amps remaining)
Bondo 11-01-2010 09:20 AM
Ayuh,... Thanks Allen,...
Anticipated load is 3 60w overhead lights, 'n maybe a tablelamp...
Outlet loads should only be a TV, 'n possible a small music center...
I think a single 20amp circuit should cover it all...
Also,... All wiring is 12ga. 3 conductor wire...
jmc1981 11-01-2010 09:21 AM
Just make sure you have a flash light in your back pocket every time you plug in something.
Scuba_Dave 11-01-2010 09:28 AM
I have flashlights in my house
Not hard to find them when needed
And my key chain has a small LED flashlight
And I've had far more short power outages from weather etc VS breakers tripping
