Old 01-19-2011, 08:17 AM   #1
lighting my tool cabinet
I am building a tool cabinet and wanted to wire some lighting into it. I bought a rope light that plugs into the wall: http://www.homedepot.com/webapp/wcs/...57&R=100177957
and wanted to mount an illuminated push button switch on the outside of the cabinet to turn it on and off. So i bought this: http://www.radioshack.com/product/in...87#tabsetBasic
I guess this switch won't work and isn't rated for wall power? I was going to splice the switch into the power cord to the lights, but this probably isn't safe?
Does anyone have any suggestions on how i can accomplish my goal? thanks.
seanhavlik is offline   Reply With Quote
Old 01-19-2011, 08:40 AM   #2
neither link are working for me, but I assume you have a 120v rope light and a 12v switch, this will work, right up to the point it burns your house down. you either need to use a 12v relay that will control 120v, that will also require a separate power supply for the low voltage side. your easiest solution is a proper toggle switch.
dhubz is offline   Reply With Quote
Old 01-19-2011, 08:44 AM   #3
Hey Seanhavlik,
I am Gregg with the Home Depot in Chicago. Where is the outlet that the rope lighting is going to be plugged in at? Is it going to be in the cabinet or on the wall? The first solution that comes to mind is installing a light switch that controls the outlet. You can put the switch somewhere convenient to the work area, but ask an electrician how or have an electrician help you do it correctly. Another option, which is a little easier, is plugging the rope lighting into this lamp dimmer.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
This lamp dimmer can turn the rope lighting on and off and you can set the switch part anywhere. I hope this helps. If you have any other ideas or questions let me know. –Gregg
gotogregg is offline   Reply With Quote
Installing under cabinet lighting trim? kcrossley2 Kitchen & Bath Remodeling 5 11-13-2012 09:38 PM
Under cabinet lighting (Valence lighting) FredS Electrical 4 05-15-2010 11:18 PM
Task force 5 drawer tool cabinet whataboutj Tools 1 05-11-2010 01:41 PM
Under cabinet lighting direct wiring Schwarzaroo Electrical 5 12-30-2008 10:25 PM
