Lighting For Low Basement Ceiling - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 05:51 AM   #16
Originally Posted by South Portlander View Post
Many months later.... Here is what it looks like with everything painted white (I blasted it with a rented sprayer) and track lights between the joists. I never got around to sheetrocking anything. After all, it's just the basement, right? I'm adding some color to the walls and putting down some carpet. Then it'll be pretty much done. I'm pretty happy with how it's coming considering the dungeon that it was before.
reppin the 04106!
Originally Posted by Jim Port View Post
You do know that this thread is over 3 years old.
sure rise it from the grave!
Tiny207 is offline   Reply With Quote
Old 01-28-2012, 06:25 AM   #17
Rewards Points: 1,548
This thread was probably found via a Google search.
(suitable poll question) Who would prefer that the first 2012 poster do no research at all and start a new thread from that point?
I suggest a compromise; if I can't find anything after eight minutes of searching (anywhere) I feel it is kosher to start a new thread.
Often the utilities and hardware in the ceiling can be made less conspicuous by painting it all flat black. This does have the disadvantage that light bounce down from the ceiling is foregone, necessitating more new light to start with. Black above for a home theater kills two birds; the second is that the amount of light from the screen that bounces around and back onto the screen should be minimized.
Generally can lights need to be spaced closer together in a low ceiling.
Necessary to insulate basement ceiling between joists? yummy mummy Building & Construction 12 02-06-2009 11:19 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
Recessed Lighting In Basement Rifeman Remodeling 12 09-06-2007 01:26 PM
basement ceiling joists-how to know if they are level? yummy mummy Building & Construction 22 02-06-2007 08:16 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
