Lighting Help - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2007, 06:52 AM   #1
Lighting Help
I'm fitting flush fit lighting in my bathroom and downstairs toilet, this is the existing wiring and at the bottom the instructions for the new unit, which goes where?
martincooke is offline   Reply With Quote
Old 09-10-2007, 08:34 AM   #2
Once fried, twice shy.
elkangorito's Avatar
In what country do you live?
Anyway, on the right hand side (RHS) of your photo, shows the 'active' supply (otherwise known as 'hot' or 'line') with brown wiring. On the LHS, the neutral wires are coloured blue. The wires in the middle of the terminal block appear to be connected in the 'loop' terminal, which you mustn't touch.
Don't forget to turn off the power at your main circuit breaker/switch before performing any electrical work.
elkangorito is offline   Reply With Quote
Old 09-10-2007, 08:44 AM   #3
I'm in UK, the house as just been built.
Old 09-10-2007, 09:31 AM   #4
Lights fitted and working
lighting guideline's - kitchen remodel dcd22 Electrical 3 08-01-2007 11:50 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
Calculating lighting wbjdmd Electrical 18 11-01-2006 05:18 PM
