Old 03-08-2011, 09:31 PM   #1
Lighting fixture may not be supported by nonmetallic conduit
Section 347-3(b) in the NEC says that a lighting fixture may not be supported by nonmetallic conduit (pvc.) Is this the same as strapping a box to an outside wall, running pvc (properly bracketed) to the box from a jb at the sill and attaching the light fixture to the box?
Thank you,
Ed
whatrymes is offline   Reply With Quote
Old 03-08-2011, 10:43 PM   #2
No this mostly refers to using a piece of pipe to span joists and hanging the light of the the pipe with fixture chain.
Jj375 is offline   Reply With Quote
Old 03-09-2011, 11:06 AM   #3
Electrician
SD515's Avatar
I'm not sure what section you are refering to. I don't have the 2011 NEC, but Article 347 doesn't exist in the 2008 NEC.
To answer your question, indepentantly securing the box to the building and mounting the light fixture to that is acceptable, as the RNC is not supporting the light...the box is.
Kyle
Old 03-09-2011, 12:24 PM   #4
J. V.'s Avatar
To answer your question, independently securing the box to the building and mounting the light fixture to that is acceptable, as the RNC is not supporting the light...the box is.
Correct on both points.
Old 03-09-2011, 02:52 PM   #5
Electrician
SD515's Avatar
Kyle
Old 03-09-2011, 06:36 PM   #6
Sorry, I'm looking at 1999 NEC.
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
DIY Lighting Fixture stubits Electrical 11 10-13-2009 02:20 PM
Help with a lighting fixture llVeXXll Electrical 2 09-16-2009 10:29 PM
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 05:42 PM
Installing Lighting Fixture lilsara88 Electrical 3 01-03-2009 09:49 PM
