-   -   Lighting Conversion (http://www.diychatroom.com/f18/lighting-conversion-30731/)
kennykenny 10-27-2008 04:17 PM
Lighting Conversion
I am wanting to add a double pendant lighting kit in the place of a recessed can light over my island in my kitchen. I am hoping to use "The Can Converter" which allows you to covert a can to accept hanging lights, flush mounts, ceiling fans and track lights. My questions is, the "Can Converter" says that it will accept up to 35 lbs. My pendant is 40lbs. Do you think that it will be a hazard to go over the weight limit? The existing can was installed when the house was built. There is no reinforcement with can lights like with ceiling fans. Right?
I know that there are braces that you can add with limited ceiling access. With recessed lighting, do you have to remove the existing can in the ceiling? If so, how do you remove the existing "new construction" cans? Is this difficult? Thanks!
220/221 10-27-2008 04:36 PM
First, make sure your cans are not retro fitted remodel cans.
Second, those things are a little unsightly.
Third, just because the harware is rated for 30 pounds doesn't mean the existing can is. I'm not sure that some can's I've installed would cleanly hold 40 pounds. Thats a good sized fixture....3 bowling balls????
I'd just yank the can out. To explore, just remove the trim and the 3 screws inside the can and pull it out or push it up. You will see the JB and the framing above the ceiling.
joed 10-27-2008 07:13 PM
If the kit says 35 lbs then that is the limit not 40 lbs.
