Lighting Control - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 10:04 AM   #1
Unhappy
Lighting Control
Hi,
I'm trying to install 347V lighting fixtures in my home office, but I have a 120V lighting control relay panel. Will that be a problem?
C_Morgan is offline   Reply With Quote
Old 08-26-2010, 10:08 AM   #2
Is this a flourscent fixture with a ballast? Pictures would help.
macdonald is offline   Reply With Quote
Old 08-26-2010, 10:26 AM   #3
Yup, T8 Fluorescent with instant start electronic ballasts. Recessed parabolic for t-bar ceiling. I don't have a picture readily available, but here's the closest thing I found:
http://www.viscor.com/catalog/DCFP/QPDF.pdf
The specs are pretty similar, 2 32 watt lamps, 347V linear fluorescent.
Old 08-26-2010, 10:42 AM   #4
You'll be fine. Read the ballast and it should say input 120V AC etc and and the output will be correct for the bulbs it lists to use.
Old 08-26-2010, 11:22 AM   #5
I'm sorry, I'm new to the DIY scene, could you explain a bit more how you mean? The 347V lighting fixture will have a 120V AC ballast which will allow it to interact with the 120V lighting control panel? Will this be able to work with a standard light switch?
Thanks!
Old 08-26-2010, 04:23 PM   #6
In simple terms, the ballast converts the 120volts into the 347volts required for your light. So yes, it will work on any 120 volt circuit.
Old 08-26-2010, 04:49 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by C_Morgan View Post
Hi,
These fixtures are available in 347v and 120v. Which ones do you have?
If they are 347v input they are NOT usable to you. Or most anyone else for that matter. 347v is extraordinarily rare.
Old 08-26-2010, 04:53 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Isn't that a Canadian voltage?
jbfan is online now   Reply With Quote
Old 08-26-2010, 06:22 PM   #9
Maybe in an industrial setting.
Residentially I thought they were the same 120/240v as us.
Lighting - Control Factor? mstefan Electrical 1 05-21-2010 07:50 PM
Need lighting control solution mmccarty Electrical 9 08-25-2009 10:13 PM
track lighting turns on and no longer has dimmer control nyfilm123 Electrical 5 06-05-2009 12:03 AM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
