Old 08-05-2008, 05:51 PM   #1
lighting circuit
I am trying to find out if what i want to do is possible?
I would like to be alble to control two lights independently and together from two locations for example: two lights above my bed on each side of the bed, would like to have a switch on each side of the bed and be able to have either both lights on or one side or the other on. I hope this makes sense.
wormyaz is offline   Reply With Quote
Old 08-05-2008, 07:01 PM   #2
joed's Avatar
lighting circuit
You will need two switches on each side of the bed, one for each light.
Old 08-05-2008, 07:49 PM   #3
It was a dark and stormy
Yoyizit's Avatar
lighting circuit
Just so I have the logic straight, switch #1 controls light #1, switch #2 controls light #2, and switch #1 has no control over light #2 and vice versa?
Old 08-05-2008, 09:16 PM   #4
Electrician
lighting circuit
You would need two switches on each side of the bed each one a 3 way switch. Of course you would need to turn on each switch to turn on both lights but who cares they are right next to each other.
chris75 is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
Recessed Lighting - How many per 20amp circuit dcd22 Electrical 10 08-27-2007 06:36 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
