Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 11:24 PM   #1
lighting
why are my can lights still glowing after i turn them off thier led bulbs
lou21 is offline   Reply With Quote
Old 04-03-2011, 11:26 PM   #2
Electrical Contractor
kbsparky's Avatar
Internal capacitors in the driver circuits discharging ... will make `em glow for a short time even after the power is turned off.
-KB
Old 04-03-2011, 11:32 PM   #3
could it be the light swicth its the kind that lights up when off
Old 04-03-2011, 11:46 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
radioactive decay?
Old 04-04-2011, 12:00 AM   #5
BIGRED
Rewards Points: 252
Do you have them on a programmable light switch? If so is the light switch good for CFL's as well as incandescents? The newer programmable switches and some dimmers use toroid coils in their electronic switching circuits to turn lights on or off or dim them. Toroid coil circuits do not recognize full off and will leave your LED lights on at 10 -30% of full brightness. Be careful not to put any LED lights on dimmer circuits unless the lamp box specificly says it is OK and also make sure the dimmer you use says it will work with LED lamps.
Grampa Bud is offline   Reply With Quote
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 02:20 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
