Lightbulbs In Office - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 07:27 PM   #1
Lightbulbs in office
I have an office with 4 in wall canned lights in the ceiling. they are arranged in a 2x2 grid located in the center of the room. There is a fan located in the center of the room, attached to the ceiling of course. The problem is, the lights (I think) get too hot, and emit too much heat for this room. What wattage light bulbs would be best to change to so that the room does not get so hot?
jashtiani is offline   Reply With Quote
Old 05-21-2013, 07:30 PM   #2
Rewards Points: 744
That's tough to answer. Lower wattage equals less heat. CFL and LED bulbs emit less heat.
Seattle2k is offline   Reply With Quote
Old 05-21-2013, 07:31 PM   #3
Rewards Points: 744
Or, you could replace the switch with a dimmer.
Old 05-21-2013, 07:48 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Well, having no idea what lamps you are using now, there is absolutely NO way to advise you what you wattage options are.
I agree with Seattle, have a dimmer installed.
Old 05-21-2013, 09:52 PM   #5
Rewards Points: 6,652
Go with LED replacements. No heat, and will last longer. As for the dimmer, I would check to make sure that the dimmer you get is compatible with CFL & LED bulbs, same for the bulbs are compatible with dimmer switches. Also if you have a iPhone on Android, there are apps, that use the camera as a light meter, and you can check the LUM of the room. Too bright, you start having headaches, too dim, you start getting eye strain.
Old 05-22-2013, 02:44 AM   #6
Rewards Points: 744
There is still a fair amount of heat, even with LED "bulbs". But, not as much as incandescent.
The Following User Says Thank You to Seattle2k For This Useful Post:
Philly Master (05-23-2013)
Old 05-22-2013, 08:43 AM   #7
Always learning...
fetzer85's Avatar
Rewards Points: 262
Is your heating & cooling system tied into your office?
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
Old 05-22-2013, 06:45 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,514
Replace the incandesant lights with CFL's or LED.
significantly less heat !
dmxtothemax is online now   Reply With Quote
Old 05-23-2013, 09:20 AM   #9
So I have attached a photo of the description of the lightbulbs. Should I switch to lower wattage or lower lumens?
Please see attachment!
Old 05-23-2013, 09:20 AM   #10
Oh, the 620 in the lower left is the lumen number.
Old 05-23-2013, 09:57 AM   #11
Incorrect. CFL's and LED's do not give off any heat. The heat they do cgive off, is due to the rectifier circuit in the base, and it is minimal.
Old 05-23-2013, 10:15 AM   #12
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
CFL's definatly give off heat ....LEDS a lot less
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following 3 Users Say Thank You to Philly Master For This Useful Post:
frenchelectrican (05-23-2013), jbfan (05-23-2013), Speedy Petey (05-23-2013)
Old 05-23-2013, 11:52 AM   #13
Thank you for the great feedback, but here are my questions.
1. Do I need to reduce the wattage of these lightbulbs? What wattage would be best?
2. Where is the best place to buy LED lightbulbs? Where is the cheapest place that I can buy LED lightbulbs for my office? What is the best brand of LED Lightbulbs?
3. How long do LED lightbulbs last?
4. Will I really need a dimmer if I put these LED lightbulbs in? Should I either put in a dimmer, or put in the LEDs?
Thank you so much!
Old 05-23-2013, 11:59 AM   #14
Originally Posted by Philly Master View Post
CFL's definitely give off heat ....LEDS a lot less
Again, it is the rectifier inside the ceramic base, not the bulb. All a CFL is, is a whole fluorescent fixture miniaturized into a compact unit.
Do not know where you are getting that CFL's give off as much heat as incandescent bulbs, but both you and Seattle2k are way off base on this one.
Old 05-23-2013, 12:00 PM   #15
LED's will last longer than the fixture will last. Average lifespan is over 25,000 hours for the low end bulbs, 50,000 to 100,000 for the more expensive units.
Home Office Build Advice Needed Charlie_ar Building & Construction 16 03-13-2013 10:36 PM
Why does outside noise travel much easier in my bedroom than my office Delta223 General DIY Discussions 6 02-15-2013 12:05 PM
Lightbulbs in Ceiling Fan! kateisstumped Electrical 5 07-20-2011 12:06 PM
Heat issue in the office repoman HVAC 1 05-08-2010 11:12 AM
New office in the basement sleepy23 Remodeling 3 08-21-2007 11:19 PM
