Light Wont Work - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 08:23 PM   #1
light wont work
5 lights and 2 outlets wont work why?
Tammie Phillips is offline   Reply With Quote
Old 12-12-2010, 08:54 PM   #2
Rewards Points: 150
You may have a breaker tripped or a blown fuse.
Steelhead is offline   Reply With Quote
Old 12-12-2010, 10:34 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Which room do the light and receptales are not working if this is in bathroom it will have GFCI receptale you should able find it and reset it but if other rooms it will varies depending on the age and how recent it was rewired in the house { the codes will change over the years so one of us will know the answer }
But try to reset the breaker first just slide to off postion but little more than you normally do and slide it back on if still not power back on yet then you may have loose connection either at the recepalte or at the switch boxes.
The most common curpit is backstabbed recepatales that where you will find loose connection second most common cupit is loose wirenuts.
If feel not too confortable with this you can get a hold someone whom know the electrical system { I rather have a electrician deal with it }
Merci.
Marc
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 01:01 PM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 11:52 AM
mercury light wont work sue gagas Electrical 1 11-14-2010 05:57 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
