Light Won't Turn Off - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 07:15 PM   #1
Rewards Points: 91
Light won't turn off
Just moved into a new house. The kitchen light above the sink stays on unless i cut the breaker. It is connected to a single switch.
I tried replacing the switch, but it still didn't work.
The conduit running to the switch has 2black wires and one ground.
What do i need to do next to figure out the problem?
no_Wedge is offline   Reply With Quote
Old 09-13-2012, 07:19 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Pull the light down and tell us how it is wired.
jbfan is online now   Reply With Quote
Old 09-13-2012, 07:24 PM   #3
Missouri Bound's Avatar
...apparently it's not.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
gregzoll (09-13-2012)
Old 09-13-2012, 07:50 PM   #4
Rewards Points: 6,652
If I had to guess, it is a miswired switch leg, and that power probably feeds either into that box, or another in the Kitchen, or miswired switched outlet.
Old 09-13-2012, 11:38 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,608
What happens if you pull the breaker,
take all the wires off the switch,
Cap them all,
then turn on the breaker ?
Does the light still turn on ?
dmxtothemax is offline   Reply With Quote
Old 09-14-2012, 03:31 AM   #6
kbsparky's Avatar
Bad switch?
-KB
Old 09-14-2012, 08:55 AM   #7
Two things come to mind. First...are you absolutely sure that switch is for the light? Where is it located? And secondly, since you have conduit () it's extremely easy to re-wire it. Open up the light fixture and see what goes where and pull or re-arrange the required wires....if that conduit actually goes to the light.
Old 09-14-2012, 07:37 PM   #8
Rewards Points: 91
i got a feeling now the switch may be to the outlet for the dishwasher/ (maybe old Disposal) let me try to disconnect and see.
Old 09-14-2012, 07:45 PM   #9
That's why I asked where it was located.
Old 09-15-2012, 12:32 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
Wedge....tomorrow is Saturday....a great day to spend the morning mapping out every single outlet and switch and noting which breaker feeds it. If you have kids....it's a good project to involve them in.
First thing I did when I moved into my house was to map out the electrical. I even go as far as to mark the breaker # on the inside of wall plates. So, if I want to work on an outlet...I pull the plate...look at the #...go turn off that breaker.
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 09:07 PM
Fixed pilot light, now furnace or AC won't turn on mjcfromct HVAC 2 10-17-2011 10:46 PM
Turn amperage down on a Light switch eriknox Electrical 18 08-22-2011 06:14 PM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
light / lamp inside speedcook microwave will not turn off Sears/GE Model 363.63673201 mtk Appliances 0 10-26-2010 06:56 PM
