Light Without Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 04:31 PM   #1
Question
light without ground
I am installing a sconce light on a wall that I cannot run wire through without cutting into the sheetrock so I am thinking of just wiring it with a lamp cord. The lamp cords I've seen do not have a ground wire on them. Is this an issue for a sconce light? Should I used a three-prong cord instead?
Thank you!
Achilles97 is offline   Reply With Quote
Old 02-15-2010, 05:15 PM   #2
Licensed electrician
Rewards Points: 1,250
Neither lamp cord nor flexible cord like an extension cord is permitted to be used in place of a recognized wiring method like non-metallic cable, Type AC or MC cable or a conduit system.
Old 02-15-2010, 06:32 PM   #3
Just call me Andrew
Rewards Points: 1,020
Do you mean you just want to hang the sconce, run the "lamp cord" down the wall and plug it into an outlet?
Andrew
secutanudu is offline   Reply With Quote
Old 02-15-2010, 08:38 PM   #4
Yes. The wiring will not be in the wall at all. The scone will be mounted to a wooden box and the box attached to the wall. The cord will come out of a hole in the bottom of the box and plug into the outlet. I would wire the lamp cord to the sconce but it would not be grounded.
Thank you very much for the help.
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Ground question. mystery guest Electrical 5 07-24-2008 01:47 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 02:50 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
