Light Wired From Socket - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 05:14 PM   #1
Light wired from socket
can a feed for a light be taken from a socket??
william11 is offline   Reply With Quote
Old 03-06-2011, 05:19 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
That depends. Where is the receptacle and what else is on that circuit? is the receptacle switched or does it have constant power?
iminaquagmire is offline   Reply With Quote
Old 03-06-2011, 05:22 PM   #3
constant power the soket is in the kitchen over the counter the lights are going to be under the press
Old 03-06-2011, 05:28 PM   #4
Licensed electrician
Rewards Points: 1,788
The small appliance countertop circuits cannot be used for lighting.
Old 03-06-2011, 05:30 PM   #5
there is 4 sockets on the circuit with a 20amp mcb why will this not do
Old 03-06-2011, 05:42 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
william11 there is 4 sockets on the circuit with a 20amp mcb why will this not do
because the National Electrical Code (which is used in almost the entire country) does not allow lights to be fed from the circuits that provide power for the counters in a kitchen.
Old 03-06-2011, 05:48 PM   #7
but it can be done the light will only be on for about a half an hour every day.
Old 03-06-2011, 05:49 PM   #8
nap
You talking to me?
nap's Avatar
it doesn't make any difference. It just is not allowed to be wired like that.
Old 03-06-2011, 05:56 PM   #9
i have the wire in so sorry its gonna have to do now was just wondering do i a spur because im going from 2.5 to 1.5
Old 03-06-2011, 06:05 PM   #10
Rewards Points: 1,542
Use a portable light fixture that can be hung on the wall (the fixture has a cord and plug).
Old 03-06-2011, 06:07 PM   #11
Another I don't like the answer I got so I will ignore it and install something not to code. Would you take the same approach about brain surgery?
What is 2.5 and 1.5?
Old 03-06-2011, 06:09 PM   #12
nap
You talking to me?
nap's Avatar
he's not in the US.
notice the term "spur" and the 1.5 and 2.5 are wire sizes.
where are you william?
Old 03-06-2011, 06:13 PM   #13
joed's Avatar
Rewards Points: 13,358
The term MCB and spur tells me you are not in USA. You must be in UK. The rules over there are completely different. You might be fine. Maybe someone with UK experience will come by and give a yes or no.
Old 03-06-2011, 06:19 PM   #14
im in ireland guys 2.5 and 1,5 square cable.sorry its just the wire is in already
Old 03-06-2011, 06:25 PM   #15
Most of the advise given here is based on the US codes.
Without your location filled in it is hard to know what applies to your situation.
I apologize for sounding harsh. Many professionals here try very hard to give accurate advise to ensure someone knows how to do things safely.
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
Changing a Outdoor light to a socket la15ota Electrical 5 10-14-2009 01:49 PM
Best way to hide overcut drywall with light socket Red Squirrel Drywall & Plaster 7 08-17-2009 11:24 AM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 09:48 PM
