Light Will Not Work - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 09:26 AM   #1
light will not work
I have a light that is controlled by a switch. It stopped working.
The two white wires are connected
The two grounds are connected and the two black wires are connected to the switch.
I have used a tester and touched the probes to the black and ground wires so the wire to the switch is hot
The wire to the light is hooked up white to white, black to black and ground to ground
The light will not work
I have used a tester on the wire coming from the switch and touched the probes to the black and ground wires and it is hot
The light works because I have attached it to another switch
jcjc320 is offline   Reply With Quote
Old 07-08-2009, 10:27 AM   #2
well if the two blacks are on the switch that means the white is passing though the switch box w/ out be connected to anything correct? So the light should be at the end of the circuit. Make sure the white is connected to the silver screw and the black to the brass colored screw. If all connections are tight put a new switch in.
mike242424 is offline   Reply With Quote
Old 07-08-2009, 10:38 AM   #3
Rewards Points: 246
Change out the switch, if you know your wires are connected exactly like they were before.
Old 07-08-2009, 11:01 AM   #4
joed's Avatar
Rewards Points: 13,728
Test between black and white instead of black and ground. I suspect you have an open white wire somewhere on the circuit.
Old 07-08-2009, 12:22 PM   #5
Rewards Points: 508
Send a message via AIM to theatretch85
That is certaintly possible.
One of the things I'd try is to bypass the switch by wiring the 2 black wires together to see if the light comes on. Also, as suggested check the voltage between the incoming black and white wires.
theatretch85 is offline   Reply With Quote
Old 07-08-2009, 01:01 PM   #6
You are confused. No neutral terminals on a switch.
Like Joed said, you need to test hot to neutral, not just ground.
Slip one end of the tester in the white's wire nut (or carefull remove it) and test to BOTH terminals on the switch. One black is power in, the other goes to the light.
If you have voltage on both terminals to ground but not to neutral, the path back (neutral) is broken (open), likely in a feed thru back stabbed recep.
220/221 is offline   Reply With Quote
Old 07-08-2009, 01:09 PM   #7
Rewards Points: 508
I believe he was referring to the light fixture. Though some light up switches do require a neutral (although the op did not describe anything that resembled a light up switch). Electrically the light would still work with the hot/neutral reversed, HOWEVER it is hazard as the outer metal ring on the socket would become energized and simply changing a light bulb with the switch on could be a shocking experience!
Old 07-08-2009, 01:10 PM   #8
i was talking about the light fixture not the light switch. sorry for the confusion
Old 07-08-2009, 01:14 PM   #9
I was just trying to keep the OP from getting off track.
Old 07-08-2009, 07:12 PM   #10
On the wire coming into the switch
I tested Black to ground and the tester lights
I tested Black to White and nothing
Old 07-08-2009, 08:49 PM   #11
Journeyman Wireman
You lost your neutral somewhere. Maybe a receptacle nearby? Another switch somewhere? Can tell what's on that circuit by shutting it off. Check for a bad connection.
jbberns is offline   Reply With Quote
Old 07-08-2009, 10:36 PM   #12
Well...
Remove the closest recetacle on that circuit and take a look
Old 07-15-2009, 07:18 AM   #13
Thanks everybody
The issue was with the receptacle next to the switch. The neutrals were only taped together and came apart
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 01:01 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 07:28 PM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 10:12 PM
