Light Type - Electrical - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 06:59 PM   #1
Light type
Anybody know the difference between high pressure sodium and mercury vapor as far as the type of light they give off?
Mule98 is offline   Reply With Quote
Old 02-07-2013, 07:16 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
HPS=Very Yellow/Orange
MH/MV=White with a very minor blue tint
The Following User Says Thank You to k_buz For This Useful Post:
Mule98 (02-07-2013)
Old 02-07-2013, 10:00 PM   #3
Electrical Enthusiast
Rewards Points: 504
In addition, you can probably look around your area at night to see the difference in the colors. Mercury vapors give off a cool bluish glow, high pressure sodiums are a yellow color (used in many streetlights now).
Usually it is just a preference issue; I like mercury vapor, but many others like high pressure sodium.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Mule98 (02-08-2013)
Old 02-07-2013, 10:06 PM   #4
Oso954's Avatar
Rewards Points: 724
Mercury vapor fixtures and ballasts have not been made or imported to the US since 2008. So, unless you find either used or NOS, you are out of luck.
There is also discussion of banning the bulbs after 2016.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Mule98 (02-08-2013)
Old 02-07-2013, 11:40 PM   #5
Rewards Points: 504
I hate that, I like Mercury Vapor lights...oh well. Aren't there other things we need to be banning?
Old 02-08-2013, 12:32 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
I can think of a lot of things....we could start with politicians.....
But getting back on topic.....
Not sure why you want to go with Mercury Vapor....They take 5-7 min to get to full brightness....their efficiency is no better than CFL....they produce a lot of UV...but do have a long life....typically 24K hours or so....
The Metal Halide is a close version of MV lights.
Low press sodium has almost twice the efficiency as MV.
The Following User Says Thank You to ddawg16 For This Useful Post:
Mule98 (02-08-2013)
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 07:49 AM
Wiring a Shed light & internal power DJDesq Electrical 4 08-12-2012 09:12 PM
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 04:23 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
