Light Switches In A Mobile Home - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 09:23 PM   #1
light switches in a mobile home
needing to replace a light switch in a 1997 mobile home. Went to lowes and said that I could just use a regular light switch but when I took out the box it had 3 different sets of wires going to the old switch 3 black, 3 white and 3 copper. What do I do with all these wires?
mobilehome is offline   Reply With Quote
Old 07-25-2010, 09:27 PM   #2
Electrician
Proby's Avatar
Take a picture of it.
Proby is offline   Reply With Quote
Old 07-26-2010, 01:37 AM   #3
" Euro " electrician
frenchelectrican's Avatar
It should able use the standard light switch so therefore all the bare conductors are wirenutted or crimped then all the whites are together and wirenutted and last thing is you have to know which one is your power source and one for the luminaire once you sort it out it pretty easy to make a pigtail and hook it up.
The best thing is take a picture and you should have a junction box in there as well due that kinda pretty new MH you have there so it should not have that oddball switch at all.
Merci.
Marc
Old 07-26-2010, 05:25 PM   #4
Electrical Contractor
kbsparky's Avatar
It sounds like one of those self-contained switches that do not require an outlet box. Personally, I detest those devices ...
The OP will have to get a pop-in type box, and install that in the hole in the wall left behind by the old wall switch.
Strip the sheathing from the cables, and install them into the box, and then make it up like any other "normal" switch. Identifying the switch leg will be an important part of successfully completing this task.
-KB
Old 09-07-2011, 02:53 PM   #5
I too am having a problem figuring out how to replace a light/fan switch in my living room. I have pictures of what is there now and the box and switch I want to replace the old with. Too many wires for switch I got? I would greatly appreciate any advice, suggestions or HELP!!
Thanks so much!
light switches in a mobile home-p9071741.jpg   light switches in a mobile home-p9071742.jpg
saggioculo is offline   Reply With Quote
Old 09-07-2011, 04:10 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Remove the existing switch, pull the cables into and install that blue old work box. Twist the whites together and install a wire nut (they are not connected to the switch). Pig tail the bare grounds together and connect to the ground on that new switch (you need a short piece of bare wire to make up the pigtail). Connect the 2 blacks to the new switch.
Coastal South Carolina
Old 09-10-2011, 06:36 PM   #7
So, I won't be using the white wires at all? I'm confused because the white wires seem to be used in the old switch. I'm so afraid of electricity but I'm more afraid of a professional electrician bill just to change a light switch.
Thanks so much for all your help!
Anne
Old 09-10-2011, 07:22 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
The white wires wonít attach to the switch. They only appeared to on your original switch, but they were actually only connected to each other inside of it. Strip back and remove a couple more inches of the sheathing of both cables before you put them in the new box and put the box into the wall. Youíll need more free conductor to work with. Be aware the sheathing has to enter the box though, so donít take too much off. Also cut both white wires back to get rid of the knick in the insulation.
Kyle
Old 09-10-2011, 08:31 PM   #9
Thadius856's Avatar
Rewards Points: 504
Neutral conductors are never switched. Strip them back and nut them together.
Thadius856 is offline   Reply With Quote
Old 09-10-2011, 09:24 PM   #10
Electrician
SD515's Avatar
Rewards Points: 504
Not true. Neutral are rarely switched.
You can use a switch to disconnect a neutral if all of the ungrounded conductors of that circuit are simultaneously disconnected, or be arranged so that the neutral can’t be disconnected until all the ungrounded conductors are disconnected first.
I know what you mean, it’s just inaccurate to say never.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
frenchelectrican (09-11-2011)
Old 09-11-2011, 10:16 AM   #11
Thadius856's Avatar
Rewards Points: 504
You can use a switch to disconnect a neutral if all of the ungrounded conductors of that circuit are simultaneously disconnected, or be arranged so that the neutral canít be disconnected until all the ungrounded conductors are disconnected first.
I know what you mean, itís just inaccurate to say never.
Hmmmm. Never heard that one.
Would it be accurate to say that's rare in basic residential applications?
Old 09-11-2011, 11:38 AM   #12
Electrician
SD515's Avatar
Rewards Points: 504
It’s an exception to 404.2(B). Yes it’s rarely, if ever, used in residential. Don’t think I’ve ever seen it done in a house, usually no need to.
Kyle
Old 09-18-2011, 09:52 AM   #13
So, I followed the directions from you nice folks and my light is fixed! Thank you so much for your instructions. It may not seem like much to some but for someone on a fixed income, being able to fix my own light switch instead of paying a "professional" is like winning the lottery. OK not like winning the lottery but maybe like finding $10 bucks in the pocket of an old coat.
Anyway, thank you again for your help, I truly appreciate it.
Anne
Old 07-23-2015, 08:24 AM   #14
Rewards Points: 8
mobil home light switches
Hello, im trying to help a friend out by replacing his bathroom switches there is three side by side I pulled all three out put new boxes in put all new switches in easy right , "wrong" and the only wire I had to add was the jumper from box to box . whats wrong here ????
thumper ken is offline   Reply With Quote
Old 07-23-2015, 09:32 AM   #15
A "Handy Husband"
rjniles's Avatar
A few things wrong.
Hijacking a 4 year old thread.
Not posting a picture so we know what you are talking about.
Doing electrical work for someone else when you don't know what you are doing.
The Following 3 Users Say Thank You to rjniles For This Useful Post:
InPhase277 (07-24-2015), Jim Port (07-23-2015), Speedy Petey (07-23-2015)
2 switches 2 lights line in through light 1 bldaz Electrical 9 12-24-2009 06:42 PM
2x Three Way Light Switch - switches out of sync zurgdawg Electrical 9 12-18-2009 07:20 AM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
mobile home light switch handy mama Electrical 3 03-12-2009 09:48 PM
Dyrwall for Mobile Home Suncrest79 Building & Construction 3 03-04-2009 07:05 AM
