Light Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2009, 10:00 AM   #1
light switches
three yrs ago had an addition put on my house, problem is all my light switches sounds like they are sparking behind the plate, some lights only work half the time. any suggestions,loose wires, switches junk already? thanks
sldhed is offline   Reply With Quote
Old 07-24-2009, 10:32 AM   #2
If they really are drawing an arc an AM radio tuned between stations should pick this up, but you first need to know what the 'pop' that a normal switch transmits sounds like on the radio.
Old 07-24-2009, 11:46 AM   #3
Rewards Points: 126
Pull each one out of the box with the power turned off. Replace each switch and make sure you have good connections. Yep, thats it.
Old 07-24-2009, 01:38 PM   #4
The expert
StarPollux99's Avatar
Send a message via AIM to StarPollux99
Was gonna post this exact thing. Any update?
StarPollux99 is offline   Reply With Quote
Old 07-24-2009, 01:46 PM   #5
I guess I'd look for the root cause of this massive failure.
Old 07-25-2009, 11:02 AM   #6
Rewards Points: 126
Cheap switches and or bad craftsmanship. Connections in particular. Also, over time electrical devices heat up and cool down. This natural occurrence causes connections to lose their integrity.
Come On. Hes not trying to get his house ISO certified.
Old 07-25-2009, 11:31 AM   #7
Root cause =
normal aging and/or
defective parts and/or
not installed in a workmanlike manner
I'll go with that.
Old 07-25-2009, 12:55 PM   #8
Rewards Points: 1,016
Some years back I bought a new house. Over time switches and outlets were not working, sometimes... Found the wires wrapped around the screws but the screw not tightened. After fixing a couple offending this way, I opened up all the switches and outlets - virtually all were like this...
Old 07-25-2009, 01:03 PM   #9
Ok, let's add
lack of due diligence and
lack of duty of care
to the root cause.
The fix for these causes is probably more lawsuits.
Old 07-26-2009, 04:24 PM   #10
appreciate the responses, i am going to go with cheap switches due to the fact that i saw a lot of home depot bags around when the licensed electrician was working. now to replace these, what brand is a good one? again thank you
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Separating Fan and Light Switches GeauxCajuns82 Electrical 11 08-26-2008 12:03 AM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 01:57 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
