Light Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2014, 11:17 AM   #1
Rewards Points: 4
Light Switch wiring
I am trying to wire led lights that are under my bed to a switch in the wall like a light switch. The only part to this, is that I want to have the led lights turn on, when I turn the light switch to the ceiling lights off (acting as sort of a night light). Is there any way possible to do this? Thought the idea sounds cool but I dont know what I would need to make it work. Thank you in advanve for your help.
bbeja is offline   Reply With Quote
Old 11-10-2014, 11:41 AM   #2
Rewards Points: 248
Use a 3-way switch. It's always on in one direction. The hot wire will go on the common terminal.
Jake. is offline   Reply With Quote
Old 11-10-2014, 11:41 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You need to add a receptacle to the wall to plug the LED lights into, that receptacle is then controlled by a single pole, double throw, center off switch with switch function being maintained. You would simply replace the existing switch and run the appropriate new wire with a code compliant method from receptacle to new switch. This doesn't mean laying a cord across the floor ...
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 11-10-2014, 02:34 PM   #4
joed's Avatar
Rewards Points: 11,576
Three way switch will work. In one position the ceiling light will be on. In the other position the bed lights will be on.
If you want them both to be off then you will need a second switch or one like Stubbie describes with a center off.
The Following User Says Thank You to joed For This Useful Post:
Stubbie (11-10-2014)
Old 11-10-2014, 03:43 PM   #5
Rewards Points: 248
You could put a stack-switch: single pole/3-way for the second "all-off" position. Or just 2 single poles.
Old 11-10-2014, 04:48 PM   #6
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
The effect sounds cool though.
Not necessarily for a bedroom. I need darkness.
clw1963 is offline   Reply With Quote
3-way switch wiring (for kitchen light) mikevoth Electrical 22 04-13-2013 12:37 AM
Wiring instructions for a motion sensing light switch kfwhitfo Electrical 1 03-02-2013 03:15 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 07:27 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
