Light Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 05:10 PM   #1
Rewards Points: 172
Light Switch wiring
Hello:
I posted this image a while back and was told it was the correct layout. I have wiring diagram book at my home and the book shows the incoming hot on the top screw for the light switch when running power through the light. Does it matter which hot goes on the top or bottom screw in this scenario?
Here is the original layout:
zephed666 is offline   Reply With Quote
Old 05-04-2011, 05:17 PM   #2
Rewards Points: 320
It doesn't matter which screw you put the hot to on a single pole switch. I like to use the red for the switched power for lights and the black for the unswitched power but either way is correct.
teamo is offline   Reply With Quote
The Following User Says Thank You to teamo For This Useful Post:
zephed666 (05-04-2011)
Old 05-04-2011, 05:24 PM   #3
Rewards Points: 172
So top or bottom no worries?
Old 05-04-2011, 05:38 PM   #4
No worries
heartlessmcfly is offline   Reply With Quote
The Following User Says Thank You to heartlessmcfly For This Useful Post:
Wiring a single pole wall switch to a ceiling fan and light. How ? Larry Lambert Electrical 3 03-08-2011 03:52 PM
wiring in line light switch on power cord basicbrand Electrical 4 12-08-2009 09:36 AM
wiring receptacle form light switch olazu Electrical 8 12-03-2009 09:10 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
