Light Switch Wires Help. Really Confused - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 04:10 PM   #31
Rewards Points: 2,512
We will assume that wire "B" is the other end of wire #4 since they are both red.
Is wire "C" connected to the light fixture?
Regarding wire "A", which wire, #1, 32 or #3 is its other end?
hammerlane is offline   Reply With Quote
Old 01-05-2013, 04:27 PM   #32
I did an ohm test with the power off. C is connected to #2 and A is connected to #3. that is all they returned with. Thanks!
Sandman22 is offline   Reply With Quote
Old 01-05-2013, 05:17 PM   #33
Is wire#1's other end at the simple kitchen lite?
Old 01-05-2013, 05:29 PM   #34
I took a reading from the 2 wires at the end of light fixture #1 (the 2 wires coming into the fixture w/the bulb) and it showed connected to #1 and #6 with the ohm test. thanks!
Old 01-05-2013, 05:38 PM   #35
would putting wingnuts on wires #2, #3, #4 (since we removed the hidden switch connected to these)seperately and then pigtailing #1 and #6 together and add new wires from the pigtail to the skylight switch and light fixture 1 switch work for a quick test? seems #6 has the juice...but this is all slob talk as i am a computer guy and not an electrician .
Old 01-06-2013, 07:31 AM   #36
would seems #6 has the juice...but this is all slob talk as i am a computer guy and not an electrician .
Back in post #14 you stated,
"I tested all 6 individual wires to the white wires(there are 5 white wires pigtailed together) and only wire #5 returned a hot connection. The rest did not. "
How did wire #6 suddenly have the juice?
Old 01-06-2013, 11:37 AM   #37
Sorry that was a typo. I meant should i pigtail the wires to #5 as a test? Thank you!
Old 01-06-2013, 12:03 PM   #38
Connecting your constant hot wire which you say is #5 to the switch leg(which has yet to be determined) should turn the simple kitchen light on.
In the diagram below, connecting the blue and black together at the switch location--in essence eliminating the switch----will turn the light on.
The blue wire is the switch leg.
Light Switch Wires Help. Really Confused-one-sp-switch-one-lite-power-switch.jpg   Light Switch Wires Help. Really Confused-gegeet.jpg
Old 01-07-2013, 11:38 PM   #39
This is now complete and fully working!! thanks to all the advice, i was able to determine which wires went where and got it all setup.
Old 01-07-2013, 11:40 PM   #40
Edit: Duplicate post.
Old light switch, only two wires? AustinTexas Electrical 5 07-23-2011 08:38 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
single light switch with 3 14-2 wires Larry Penny Electrical 2 08-26-2010 05:13 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
