Light Switch Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 03:58 PM   #1
Light switch wires
Right ok! I have removed a light switch what is 2 way but only using it as one way, the only wire what were connected to comm terminal were 2 red wires twisted together, why is this?? As i want to replace this switch!
Thanks in advance
Ramsay19 is offline   Reply With Quote
Old 01-02-2012, 04:32 PM   #2
Most likely one red wire is power and the other red wire continues on to power something else like an outlet or another light.
Billy_Bob is offline   Reply With Quote
Old 01-03-2012, 09:02 AM   #3
Thanks!
Old 01-03-2012, 01:50 PM   #4
Licensed electrician
Rewards Points: 1,630
Only put one conductor under a screw head. If you need to connect more than one you need to pigtail.
Need to add a light near switch in 3-way setup.... prosper50 Electrical 5 03-19-2011 09:19 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 12:09 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
two hot wires to light switch? magnolia Electrical 2 05-10-2008 03:53 PM
