Light Switch Vacancy Detector, On Two Switch Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 09:01 AM   #1
Rewards Points: 150
Light switch vacancy detector, on two switch circuit
Hoping one of the pros can lend a hand.
I have a ceiling light controlled by two light switches on either side of the room. I have a growing problem with these lights being left on all night, and I'd like to see if technology can help.
I found a light switch with vacancy detector and think this could work. It will shut off the light automatically after x minutes of non-motion.
http://www.amazon.com/Heath-Zenith-S.../dp/B001B5K6LG
Two questions:
1) Can I use something like this in a three-way circuit? (if it matters the light is inbetween the switches).
2) I read where a couple people said that the vacancy switches do not work with CF bulbs (instead of turning them off, they cause the bulbs to flicker). Is this pretty true of all vacancy switches?
sheslostcontrol is offline   Reply With Quote
Old 10-28-2010, 09:42 AM   #2
Just call me Andrew
Rewards Points: 1,020
You have to look at the specifications for both questions. Usually switches like that (more frequently called 'occupancy sensors") require a neutral to be used with CFLs.
They sell these types of switches at HD, Lowes, etc - the boxes should say if they support 3-way configuration (a lot do) and CFLs.
This one looks like what you want:
http://www.smarthome.com/2523W/Levit...r-White/p.aspx
Andrew
secutanudu is offline   Reply With Quote
Old 10-28-2010, 10:35 AM   #3
Rewards Points: 130
You have a three way switch loop, so any replacement switches would have to be three way. The one you show above will not work in your situation unless you are willing to give up the three way capability.
"This one looks like what you want" Shown above.
http://www.smarthome.com/2523W/Levit...r-White/p.aspx __________________
Old 10-28-2010, 10:54 AM   #4
Just call me Andrew
Didn't think of that - if the switch requires a neutral, he probably doesn't have one...
Andrew
Old 10-28-2010, 01:55 PM   #5
Rewards Points: 130
Two good points. The neutral and the load required to switch the motion detector. The CFL's do not pull much current at all. I am not sure motion detectors require a good load to switch or not?
Tags
light fixture , switch , vacancy
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 03:36 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
