Light Switch Trips Beaker When Turned ON - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 10:38 AM   #1
Question
Light switch trips beaker when turned ON
I swapped out 2 ceiling fans yesterday (I've installed dozens of fans and never had a problem). This required removing the slider type switch and installing the regular toggle type switch (this part I have not done before). I believe I have the wiring hooked up correctly, although I didn't have a previous wiring like this to copy. It's a double switch where one controls the fan and the other controls the light. The fan works just fine but the split second I flip the light switch, it trips the breaker.
There are 3 white wires all bound together tucked in the back of the box, 3 black wires to hook up, one of which is coming from the other light switch. And of course the ground, which are obvious to me where to connect.
Oh and the house is 7 yrs old.
Any ideas?
Cardinal is offline   Reply With Quote
Old 11-16-2011, 10:48 AM   #2
You have a short. You might have something touching something it shouldn't be inside the box your switches are in. I have found that a lot of times the ground wire may come into contact with a terminal when you push the switch back into the box.
If everything is free and clear you might have made a mistake when you hooked everything up.
Colomboj is offline   Reply With Quote
Old 11-16-2011, 10:59 AM   #3
Thanks for the response. That's what I was starting to think too. I'm going to check the fan and see if something is touching up there when I closed it up. I tested the switches before closing them up, so I know nothing was touching there.
Old 11-16-2011, 01:27 PM   #4
Rewards Points: 6,652
You hooked up the switch leg for the switch incorrectly. Take it apart and fix up in the junction box, or if you messed with the switch, double check that also.
New Light switch trips breaker C2C Electrical 6 03-11-2011 04:26 PM
adding second light from a switch agsurfer Electrical 3 09-10-2010 01:01 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 02:24 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 12:05 PM
