Light Switch Too High - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 12:56 PM   #1
hohadcr's Avatar
Rewards Points: 316
light switch too high
Hi, it is an old house, there is a light switch on the wall that is 8ft above the floor... too high to reach.
If i can find a pull switch like the one in the pic, i can then the switch verdically lower for people to reach.
But where can I get a pull swtich? doesn't need to be fancy. HD doesn't carry any pull swtichs. Amazon.com doesn't have any....
Anyone knows?
hohadcr is offline   Reply With Quote
Old 10-28-2011, 01:59 PM   #2
mem
Rewards Points: 156
I've never seen a switch like that, but then again, I don't get out much. More curiously tho, why in the world is that switch 8 feet up? ...does it control the light in that room or something like an attic light?
mem is offline   Reply With Quote
Old 10-28-2011, 03:20 PM   #3
Look in the lighting department or go to a lighting store. These are added to light fixtures. You can also get extension pull chains for things like ceiling fans. Those might clip onto that chain.
Note that if you move the entire switch down, you could probably install a regular light switch.
(I say probably because there may be some reason that is like that???)
Billy_Bob is offline   Reply With Quote
The Following User Says Thank You to Billy_Bob For This Useful Post:
oh'mike (10-28-2011)
Old 10-28-2011, 05:36 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,360
Anyone knows?
You should be able to get chain like that and a joiner
like the one in the picture, from a cheap jewelery store.
You can then just extend the existing chain.
That way you dont have to change the existing switch.
Easy as !
dmxtothemax is offline   Reply With Quote
Old 10-28-2011, 07:22 PM   #5
DIY staff
Rewards Points: 7,174
Billy Bob nailed it----after you get the switch---look at the cover plates---you will find one with a small hole in it---the switch should go right in.
Old 10-29-2011, 12:33 PM   #6
Electrical Contractor
That is pretty common in early 20th century victorian homes, at least around here. I would use that as a junction box and drop a new switch down to a comfortable height. We have to install them at max height of 48" to meet ADA.
Sine is offline   Reply With Quote
Old 10-30-2011, 06:25 PM   #7
hohadcr's Avatar
Rewards Points: 316
not sure if i asked the question right.
im hoping to find a pull switch to put in the current high switch box, w/o actually moving the box.
light stored?
Old 10-30-2011, 06:36 PM   #8
Rewards Points: 340
Would this work? - Note the switch rating may be a little low.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
tribe_fan is offline   Reply With Quote
Old 10-30-2011, 09:12 PM   #9
light stored?
So you have a regular "flip switch" up high. And you want to replace that with a pull switch?
If that is correct, then the switch/wall plate in the links above will work.
Or you can get any "blank" wall plate, then go to a "machine shop", take the switch, and they can drill the right size hole for it. (Or ask a friend, whatever...)
Again you can get these pull switches in the lighting department of a home improvement store.
Blank wall plates (no holes) are in the electrical department as are wall plates with holes in them like above.
Longer chains in the lighting department.
Old 10-31-2011, 06:57 AM   #10
Just curious,....Do you know what this switch does? If not, could this be a shut off for the heating system? A lot of homes have the furnace shut off high on the wall near the door to the basement/utility room. Often with a red switch...sometimes lit...
Can you post a picture?
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 10-31-2011, 02:09 PM   #11
hohadcr's Avatar
Rewards Points: 316
Exactly!! That is my question.
The pull switch would work , but i have a hard time imagining how to stabilize it in the switch box and with the face plate. anyone can help me?
To 1910NE, I once opened the wall and saw the wiring. So, yes, i am sure that the switch only controls a ceiling fan and the light under it.
thanks all
Blown Light Switch ogrenjr Electrical 3 03-01-2010 03:42 PM
Light switch failure help!! metalrex Electrical 22 02-04-2010 09:13 PM
Add new light and switch to a switch loop UncertainSparky Electrical 4 01-24-2010 08:58 AM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
