Light Switch - Taping Into Ground Wire Ok? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 05:32 AM   #1
SimpleJack's Avatar
Rewards Points: 31
Light switch - Taping into ground wire ok?
I changed the light switch in the spare bedroom and notice there is no ground wire connected to the old light switch and ofcourse the new switch has a place to hook up a ground, but I have no ground wire to use.
If you look in the hole in this picture you can see a ground wire that is 2 grounds with a twist nut on it.
Can I use a small peice of ground wire and wire nut it in with the rest of those wires and connect it to my light switch?
Uploaded with ImageShack.us
SimpleJack is offline   Reply With Quote
Old 08-15-2011, 05:51 AM   #2
Lic Elect/Inspector/CPO
yes that is fine
NJMarine is offline   Reply With Quote
Old 08-15-2011, 07:04 AM   #3
Rewards Points: 1,548
Originally Posted by SimpleJack View Post
... the new switch has a place to hook up a ground, but I have no ground wire to use.
Can I use a small peice of ground wire (pigtail} and wire nut it in with the rest of those wires and connect it to my light switch (green screw)?]
This is standard procedure.
Reminder:
Bundles of ground wires also need wire nuts, just twisting is not good enough these days.
Use pigtails in the fashion described here whenever two or more wires want to go under one screw.
If the box is metal, a ground wire, possibly a second pigtail, must be attached to the box, or a clip (sold separately for the purpose) inserted where the switch mounting tab (yoke) is attached to the box.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
HELP! Please. how to wire a light, switch, then outlet dcwright Electrical 6 07-06-2009 07:51 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
