Light Switch Suddenly Trips The Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 11:16 PM   #1
iff
Light switch suddenly trips the breaker
My basement lights are controlled by two light switches.
One of the switches works (turns lights on and off)
The other switch when operated trips the breaker when turning lights on.
This all started happen suddenly - no renovations or changes at all to any of the walls or addition of other electrical appliances.
I take it the issue is with the switch? What would cause this and how can I fix it?
iff is offline   Reply With Quote
Old 08-16-2012, 11:24 PM   #2
Rewards Points: 12,802
Kill the power and check for a loose connection on the switch. (and no just shutting off off the light does not count, kill the power at the breaker for that circut.
If that does not work.
Kill the power, change the switch, only undo one wire at a time. Make sure it's a three way switch that you buy.
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 06:58 PM
new light switch throwing breaker not2sure Electrical 28 04-07-2012 09:48 AM
New Light switch trips breaker C2C Electrical 6 03-11-2011 04:26 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
