Suddenly, a light switch in my bathroom stopped working. It shares a junction box with two other light switches, both of which still work. I figured it was a bad switch... replaced it. Didn't fix the problem. So, I tested the wires. They are not hot. Strange!
Description of the wiring for this switch: black wire coming from the wall. It is connected to a switch. There are two more wires that go into a cap... with a wire coming off of it and into the switch.
The other two switches in this box have a separate set of capped black wires.
I removed the caps from the two sets of black wires and capped them together. The wires going into the switch are now hot... but, the switch still does not work.
Any suggestions?
Any suggestions?
