Light Switch Reversed.. Up Is Off.. Down Is On - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 09:37 PM   #1
Light Switch Reversed.. Up is Off.. down is on
1923 House.
Dimmer in Kitchen (5 dimmable flood lights) went out.
Went to Home Depot and bought new dimmer (boucht CFL compatible dimmer as tried CFL floods before and they only lasted a few weeks)
Hooked up same way as before.. (took picture and my wife double checked) (3 black wires on top right / 1 Red wire on bottom right)
It works, but the On/Off switch is reversed.. Down is on and Up is off
mini dimmer beside switch is correct.. lights get brighter when you slide it up.
Any ideas?
caseynshan is offline   Reply With Quote
Old 05-06-2012, 10:58 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Did this dimmer have 3 screws on the sides? or a black, 2 red, and a green wire coming off it?
I think you bought a 3 way dimmer or one that could be used as one.
Old 05-06-2012, 11:37 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Flip the switch over
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-07-2012, 01:45 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Can you post the photo of this dimmer and the model number as well ?
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
plummen (05-07-2012)
Old 05-07-2012, 06:07 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Sounds like a 3 way dimmer. Move the wire connected to the terminal not marked "common" to the other terminal.
Coastal South Carolina
Old 05-07-2012, 03:06 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Or just go find the other switch and flip it.
The Following User Says Thank You to Speedy Petey For This Useful Post:
mpoulton (05-07-2012)
Old 05-07-2012, 05:36 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,970
If it's a 3-way installation (another switch also controls this light), then there is no "up" or "down". Flipping the other switch will make it so that this switch is up when the light is on.
mpoulton is offline   Reply With Quote
Old 07-12-2014, 05:08 PM   #8
I just had to switch a dead dimmer out and when I installed the new one, I had the same problem; the switch was reversed. Well, I had installed the new dimmer exactly as the old one I removed, and that was my mistake. The old one had both wires on one side of the switch, but after re-reading the directions, I moved one wire to the opposite side of the switch and that works.
Hope this helps.
SPC 17 is offline   Reply With Quote
Old 07-12-2014, 05:13 PM   #9
Rewards Points: 1,832
This thread is over 2 years old.
Jump-start is offline   Reply With Quote
Old 07-12-2014, 05:16 PM   #10
Yup But I just found it with a google search and it was useful. So I thought I could add to it for the next googlers.
Old 07-12-2014, 05:29 PM   #11
DIY staff
Rewards Points: 7,174
Thanks for waking this one up--you reminded me that the French Electrician has not been on in a while---He got married --I hope that he's doing well---
Old 07-12-2014, 06:10 PM   #12
Rewards Points: 1,476
He got hurt badly. I think his wife posted updates when it happened.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
oh'mike (07-14-2014)
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Mystery Light Switch smokey847 Electrical 3 02-04-2012 10:44 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
