Light Switch Relocation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2008, 05:13 PM   #1
Light switch relocation
Im putting in a tile shower replacing a clawfoot tub and the shower pan goes past where the light switchi s currently located. The shower pan is 34" the distance from corner to door trim is 35" It is wide trim 4.5" and can fit an electrical box there but there is a stud behind the wall where I want the switch to go. What can I do? here is a layout sketch
http://i491.photobucket.com/albums/r...coats/bath.jpg
charliewintercoats is offline   Reply With Quote
Old 12-31-2008, 08:30 PM   #2
FLip it 180 to the other side of the wall? The switch won't be in the room, but it aint the worst thing in the world.
220/221 is offline   Reply With Quote
Old 01-01-2009, 12:04 AM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
What about the wall on the right just about a 6" to a foot past where the door opens. Then you could consider the install of a motion sensor switch. Make sure the switch has a good view of the shower though so it doesn't turn off while in the shower. & or put it on a long shut off time (most can go to 30 min).
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-01-2009, 01:14 PM   #4
Agreed! This is exactly what i had to do with my b/r renos. project!
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
